Possible to change minimum designer grid size from 5 to lower?
I like using the snap to grid with grid set to 5, but i have a need to go even smaller for creating a valve template.
Is it possible to go smaller than 5? Maybe my editing a config file somewhere? Would be handy if we could choose whatever grid size we want depending on the application.
I don’t think so, but you can always turn the snap-to off and do it manually, plus there is the button to align components X pixels away from each other.
When doing layouts it is better to use a 8 point grid system rather than a 10 (or 5). This is because shapes often get divided and doubled and 8 is a power of 2 and is close to 10.
Intro to The 8-Point Grid System
Inductive, please let us choose the grid size.
-Mark
I would also like to change the grid size to a custom value, or at least the option to set the grid to 4 pixels. Easier to align and center items and layouts.
