one of my users asked me to access ignition by port 80, but i have it on the default port.
so i made a port forwarding on the server external firewall, and now i have this situation:
ext 8088 goes to 8088 (for all users)
ext 80 goes to 8088 too (for him)
it’s not a best practice, i know, anyway:
designer and clients go right when opened on the 8088.
when opened on the 80 i get an exception on the client when it launches the first sql query (the query is correct and tested):
Error executing system.db.runScalarQuery(…)
caused by Exception: Error executing system.db.runScalarQuery(…)
caused by GatewayException: Connection reset
caused by SocketException: Connection reset
the entire exception:
[code]Traceback (most recent call last):
File “event:actionPerformed”, line 17, in
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:322)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runScalarQuery(AbstractDBUtilities.java:316)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
java.lang.Exception: java.lang.Exception: Error executing system.db.runScalarQuery(SELECT ETC (removed) ETC, , )
at org.python.core.PyException.fillInStackTrace(PyException.java:70)
at java.lang.Throwable.(Throwable.java:181)
at java.lang.Exception.(Unknown Source)
at java.lang.RuntimeException.(Unknown Source)
at org.python.core.PyException.(PyException.java:46)
at org.python.core.PyException.(PyException.java:43)
at org.python.core.Py.JavaError(Py.java:481)
at org.python.core.PyReflectedFunction.call(PyReflectedFunction.java:186)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.call(ScriptManager.java:455)
at org.python.core.PyObject.call(PyObject.java:387)
at org.python.core.PyObject.call(PyObject.java:391)
at org.python.pycode._pyx4.f$0(event:actionPerformed:26)
at org.python.pycode._pyx4.call_function(event:actionPerformed)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.Py.runCode(Py.java:1261)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:539)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:155)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:266)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:55)
at $Proxy13.actionPerformed(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$000(Unknown Source)
at java.awt.EventQueue$1.run(Unknown Source)
at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$2.run(Unknown Source)
Caused by: java.lang.Exception: Error executing system.db.runScalarQuery(SELECT ETC (removed) ETC, , )
… 56 more
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Connection reset
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:312)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:450)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:248)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:243)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.runLimitQuery(GatewayInterface.java:698)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.runQuery(GatewayInterface.java:657)
at com.inductiveautomation.ignition.client.script.ClientDBUtilities._runQuery(ClientDBUtilities.java:148)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runScalarQuery(AbstractDBUtilities.java:309)
… 54 more
Caused by: java.net.SocketException: Connection reset
at java.net.SocketInputStream.read(Unknown Source)
at java.io.BufferedInputStream.fill(Unknown Source)
at java.io.BufferedInputStream.read1(Unknown Source)
at java.io.BufferedInputStream.read(Unknown Source)
at sun.net.www.http.HttpClient.parseHTTPHeader(Unknown Source)
at sun.net.www.http.HttpClient.parseHTTP(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at java.net.HttpURLConnection.getResponseCode(Unknown Source)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:374)
… 60 more
Ignition v7.5.3 (b1163)
Java: Sun Microsystems Inc. 1.6.0_33
[/code]
can i solve with a better forwarding policy or by a better configuration?
thank you
