Postgre Database connection
Hi, I trying to connect to a postgre database, the connection string is this
jdbc:postgresql://localhost:5432/postgredb
By default the data is stored in the public squema, but I want to store the data in a different esquema, how can I do this?
A Google search suggests that jdbc:postgresql://localhost:5432/postgredb?searchpath=myschema might work. Can you try it and let me know?
still does not work, the data is stored in the public schema, thanks anyway.
Hi ,
Ignition database connection for postgresql can connect to database but how to point the DB connection to particular schema in that database. I have tried by changing the connection URL to jdbc:postgresql://localhost:5432/postgredb?searchpath=myschema It didn’t worked for me.
I wanted to configure auditing profile for gateway and the auditing profile pointing to Ignition database connection so the AUDIT_EVENT table will be automatically created in the schema as per my requirement.
Hari Gb
Maybe this: postgresql schema …?
According to the documentation, it should be currentSchema
jdbc:postgresql://localhost:5432/postgredb?currentSchema=myschema
