Postgres JDBC 2nd Connection Class not found
Got an odd possible bug.
v8.1 to v8.3 conversion testing. Client has a PostgreSQL cluster with two distinct databases. Both URLs point at the same IP and port--just the DB name is different:
  • jdbc:postgresql://a.b.c.d:5432/db1?ssl=true&sslmode=require&sslfactory=org.postgresql.ssl.NonValidatingFactory
  • jdbc:postgresql://a.b.c.d:5432/db2?ssl=true&sslmode=require&sslfactory=org.postgresql.ssl.NonValidatingFactory
(Names changed. Notable possible difference: "db2" includes some uppercase characters.)
First connection works reliably.
Second connection gives me this:
java.sql.SQLException: Cannot load JDBC driver class 'org.postgresql.Driver'
	at org.apache.commons.dbcp2.DriverFactory.createDriver(DriverFactory.java:53)
	at org.apache.commons.dbcp2.BasicDataSource.createConnectionFactory(BasicDataSource.java:474)
	at org.apache.commons.dbcp2.BasicDataSource.createDataSource(BasicDataSource.java:541)
	at org.apache.commons.dbcp2.BasicDataSource.getLogWriter(BasicDataSource.java:1088)
	at org.apache.commons.dbcp2.BasicDataSourceFactory.createDataSource(BasicDataSourceFactory.java:330)
	at com.inductiveautomation.ignition.gateway.datasource.DatasourceManagerImpl.createDataSource(DatasourceManagerImpl.java:259)
	at com.inductiveautomation.ignition.gateway.IgnitionGateway.createDataSource(IgnitionGateway.java:2914)
	at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.initializeDatasource(DatasourceImpl.java:285)
	at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.runTest(DatasourceImpl.java:312)
	at com.inductiveautomation.ignition.gateway.datasource.DatasourceManagerImpl$FaultedDatasourceRetryer.lambda$newRetryRunnable$0(DatasourceManagerImpl.java:1318)
	at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$TrackedTask.run(BasicExecutionEngine.java:599)
	at java.base/java.util.concurrent.FutureTask.runAndReset(Unknown Source)
Caused by: java.lang.ClassNotFoundException: org.postgresql.Driver
	at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(Unknown Source)
	at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(Unknown Source)
	at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
	at org.eclipse.jetty.ee10.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:443)
	at org.apache.commons.dbcp2.DriverFactory.createDriver(DriverFactory.java:48)
Had to delete the driver that came through the upgrade process and then recreate the connections with the "Postgresql" instead of the "Postgresql JDBC Driver".
I'm curious why the legacy imported driver would work with one connection but not the other. :man_shrugging:
Did one have a different initial pool size?
Yes. The latter was set to initial size==4.
I can confirm that setting the initial size back to 4 broke that connection again.
I created an issue to track this.
It looks like it doesn't have anything to do with upgrades or Postgres - I think any Initial Size value is just broken.
piling on - MSSQL here, otherwise identical behavior
Summary / explanation: 8.3 database connections with Initial Pool Size > 0 fail with ClassNotFoundException for driver-jar drivers, because
setDriverClassLoader is called after BasicDataSourceFactory.createDataSource(props). Setting Initial Pool Size to 0 works around it.
I'm not sure why this needs a summary or explanation. I marked Kevin's comment as the solution.
:man_shrugging:
I'm still not sure if this needs further summary or explanation, but here ya go:
  1. this is still an issue in 8.3.10
  2. no issue number has been provided to cross reference elsewhere
  3. added additional search terms for future readers.
