I'm currently in the process of creating a named query that will fetch valve_data from a postgres database. This is done by running the following code:
SELECT * FROM valve_data WHERE valve_name IN (:tags )
For some reason this query isn't returning any value when I test it with the following value for :tags: ('CM_670BFV099030')
But when I run this in the Postgres database itself it does return values. Is my syntax for the tags wrong? I think I tried every possible method.
Trying to parameterize values for the in key word is troublesome. I think it is considered query structure and not just a value substitution. You would have to change the parameter from value to queryString. This is usually not recommended unless your parameters are sanitized (see SQL injection).
Since you are using PostgreSQL, a competent database, you have another option, as long as you use a "prep" query via script instead of a Named Query. See this discussion:
