pturmel
December 19, 2024, 4:58pm
4
Since you are using PostgreSQL, a competent database, you have another option, as long as you use a "prep" query via script instead of a Named Query. See this discussion:
If you were using a competent database (the following is PostgreSQL), you can pass java arrays as arguments, and unnest() them in a FROM clause. For an example, I created a table in my psql forum playground called phrases, to be used in a join. When queried by itself, you get this dataset:
"#NAMES"
"prefix","suffix"
"#TYPES"
"str","I"
"#ROWS","4"
"Hello","1"
"Good Bye","2"
"Welcome to","3"
"Whoa!","4"
To go with that, in a custom property named lookups, I created the following unbound datase…
