postgreSQL generate_series in v9.6 vs 12.8
Can somebody shed some light on this:
Why the same query in PostgreSQL v9.6 works and in v12.8 doesn’t anymore:
postgreSQL v9.6
postgreSQL v12.8:
I have this query in my Vision window which works in PostgreSQL v9.6 and now in v12.8 doesn’t…
postgreSQL v9.6
postgreSQL v12.8
generate_series is a set-returning function and should be in your from clause. There, you can explicitly join the two generated series.
Isn’t that what I have in my last 2 pictures?
But in 9.6 is working and in 12.8 is not…?
I don’t see a FROM keyword. Hmm. I would expect something like this:
Select dates.generate_series as "date", shifts.generate_series as "shift"
From generate_series(..........) dates Outer Join generate_series(1, 3) shifts
Untested…
BTW, did you see my comprehensive solution to the problem of varying shifts? Over here:
This IS the query:
SELECT a.datum, a.izmena, energijakosipoizmenah_new.dobri, energijakosipoizmenah_new.slabi, energijakosipoizmenah_new.porabaelektrike, energijakosipoizmenah_new.porabazraka
FROM (
	SELECT date(generate_series('2021-05-10 00:00:00'::timestamp, '2021-05-17 23:59:59','8 hour')) datum,
		generate_series(1, 3) izmena) a
LEFT OUTER JOIN energijakosipoizmenah_new ON date(a.datum) = date(energijakosipoizmenah_new.datum) AND a.izmena = energijakosipoizmenah_new.izmena;
and this is the result:
You are putting your generate_series functions into the select list of the inner query. I didn’t think you could do that, except for the fact that postgres will attempt to execute the expression. The generate_series() function returns a table (set of rows) that has the single column “generate_series”. That you were getting anything seems to be almost accidental for how this function is supposed to be be used (in the FROM clause).
OK, I found on the internet that they changed the behavior of the generate_series in version 10.
That explains why this query:
SELECT date(generate_series('2021-05-10 00:00:00'::timestamp, '2021-05-17 23:59:59','8 hour')) date,
is not working anymore.
But now how can I get the same result in v12.8 as I did in v9.6?
Try this:
FROM (
	SELECT b.generate_series datum,
		c.generate_series izmena
	FROM generate_series('2021-05-10'::date, '2021-05-17'::date,'1 day') b,
		generate_series(1, 3) c
) a
LEFT OUTER JOIN energijakosipoizmenah_new ON a.datum = date(energijakosipoizmenah_new.datum) AND a.izmena = energijakosipoizmenah_new.izmena;
Great. Thank you. :+1:
/*THIS IS WORKING!	LIKE IN 9.6*/
FROM (
	SELECT b::date datum,
		c izmena
) a
My problem was ‘8 hour’ interval in v9.6, and ‘1 day’ in v12…
