PostgreSQL Only Browse Public Schema
We are doing some testing with PostgreSQL and Timescale and I am finding that when we connect to the database that has Timescale configured Ignition is browsing dozens of tables in specific schemas that Timescale made.
My question is, how do I tell Ignition in the database connection string to only browse the public schema that contains the actual Ignition tables? I have tried setting the search_path to public for my ignition user configured in PostgreSQL and I have also tired setting ?currentSchema=public in the Ignition db connect string.
Should I be using the extra connection properties field instead? Thanks!
What is the actual connection url?
I have a postgres connection set up like this:
connect url: jdbc:postgresql://localhost:5432/ignition
extra connection properties: currentSchema=public
The connection URL is: postgresql://xxx.xxx.xxx.xxx:5432/test
EDIT:
As you can see even with this setup there are a lot of extra tables that are coming from other schemas:
did you ever find any solution? I want to do something similar, I want to create a new schema in timescale, and a single database connection to only that, and hide all of the public tables. the currentSchema prop seems to prevent the system from interacting with those other tables , but they still show up in the list and its a bit messy.
one thing that can be done is in the database translator, you can set it to exclude certain table names like hyper and those wont show up but theres still a lot of other noise.
No I did not. In fact, we found that the Timescale was about the same performance as MSSQL so it was not worth continuing to fight it.
I'm in that same situation.
Did you find a solution to this ?
No, I did not find a fix. We ultimately ended up using MariaDB and that has been working really well.
did you mark the setting to use fully qualified names?
It shows the full name, but I'd like to filter out anything that's not in a particular schema.
ie:
In this case, I'm only interested in what's in the public schema.
If I would just read the whole post...
Do you need to access other schemas with that user? I wonder if you could just grant the user permission to just have access to [public]
Have you tried using a connection initialization command? (Advanced setting.) Perhaps:
SET SCHEMA 'public';
Or perhaps:
SET search_path = 'public, some_other_schema';
did a quick test and this also does not do the trick.
May be something that needs a support ticket opened..
we do this in the connection string, and it limits what the user can interact with on that connection to it, but it still lists all the tables from every schema. I dont think theres any way to fix it, it seems the list is being populated by asking the database what tables are available, not which ones are in that schema.
