Hello,
I believe I may have stumbled across a major potential bug, and I was hoping I could get some help with reversing its effects (if possible).
The Skinny: I had a view in Perspective named "Trending" that acted as a placeholder during the beginning of development. Once I got around to it, I realized I would need multiple views to achieve the trending screen functionality we were after. So, I deleted the view named "Trending", and in the same exact spot, I created a new folder with the name (you guessed it): "Trending".
In this new "Trending" folder, I created 5 or 6 new views and got them all working together how I wanted. At this point, everything was working great. I saved everything in designer, made a quick gateway backup, and then packed away the workstation so I could demonstrate the HMI progress to the client the next day.
When I opened everything up the next day while getting ready to present, to my horror, I found that my entire "Trending" folder that I had created (as well as all the views within it) were gone. Not just that, but in place of my trending folder that I was working in just the night before was an empty/shell view titled "Trending"... Opening this view in the designer results in what is shown in Screenshot #2 below.
Needless to say, the trending screens did not work, and I was not able to demonstrate the screens that I had working perfectly fine the night before. You can see in Screenshot #1 that even the Designer got confused as to where my trending views went, as the "/trending" page was still configured to point at one of the views located within the Trending folder I had defined the night before.
The Theory: Somehow, at some point, the metadata or whatever backend magic that distinguishes folders from views got tripped up when I deleted the view named "Trending" and then created a new folder with the same exact name, and in the same exact spot. Perhaps the backend never truly "finalized" the deletion of that original Trending view until some point after I created the new folder with the same path and name, which then confused it into thinking that the Trending view was never actually deleted?
The Question: Has anyone seen/experienced this kind of bug before? And more importantly, is there any way I could get my Trending folder (with its child views) back into my project?
Side Note: I mentioned earlier that I took a gateway backup right before packing up for the demo. I took this backup while the trending screens were still working, so today I tried restoring from that backup to try to bring the views back. Unfortunately, it did not, and I am still stuck with this husk of a view in place of the folder that is supposed to be there.
I'm hoping there is some way to get those lost views back, because it took a significant amount of time and work to make them. Any help/advice would be much appreciated.
