Power Chart Component Significant Digits
I’m hoping someone else has run into a similar issue or that I’m just missing a setting or configuration somewhere that needs adjusted, but the problem that I’m facing at the moment is that we have some pressure readings that we are trying to trend on one of our work sites, but the significant digits are rounding to the hundredths place when being displayed in the PowerChart component and showing as either 0 or .01 instead of the actual values we have that hover around .005 inwc
The values we are reading, displaying, and recording for the history trends seem to be right and can be seen when you refer to the y axis on the chart or watch the live values on the SCADA pages, it is just getting rounded off on the power chart and not showing to the thousandths place for things like the minimum/maximum/average/X-trace.
I also tried to adjust the Format Strings on the UDT to something like ‘#,##0.000’ to force the display of the thousandths digit as they don’t show on the Value column in the tag browser until you click into them, but that didn’t seem to affect the power chart display. The values do show up to the thousandths place fine on the labels we use on pages other than the trends and power chart.
Does anyone know if there is a way to get the power chart to display the values for X-trace/max/min/average to show out to the thousandths and not round up and down to the hundredths?
Thank you in advance and happy holidays!
