I’m currently using the Power Chart in Ignition Perspective. When I try to print the chart, the **pen names ** are not visible or are getting hidden (both portrait and horizontal).
Has anyone else faced this issue? Is there a solution or workaround to make the pen names appear correctly when printing?
Thanks in advance
I've just checked a Power Chart view in Chrome browser and the preview looks fine. It stretches the page view to full length of an A4 page and the three pens are visible.
The pen area can be controlled through the Advanced Stylesheet. See Perspective Power Chart Pen Table Height - #4 by victordcq for a discussion on this. Make sure that someone hasn't added CSS to disable or shrink it for print output.
Thanks @Transistor for the quick reply.
I checked the link you shared. It helps with adjusting the pen table, which is already available and working. I can resize the pen table manually, and it displays correctly after resizing.
However, what I'm looking for is a way to automatically display the full chart along with all pen names without requiring the user to manually adjust or resize the pen table.
Currently, it feels like the user has to make adjustments every time, which isn't ideal.
Is there a way to make this automatic?
