Power Chart persistent pen configuration
Hello Everyone,
Currently I am using trends on respective machine dashboard, but when I. Navigate from one to on other and come back to previous again the seleyec pens gets deleted so can anyone suggest what can be setting which I am doing wrongly..
Regards,
Bharat Vinchwekar
Is this in perspective or vision?
Perspective
The power chart doesn't keep the pens that were added during runtime once you close that view. There are ways to keep the pen configuration, but they are not built in. Check out this topic:
If you want a set of pens to always be there every time for all users, you could add the pens in the designer preview and save the view. Then, every time that view is open, the power chart will start off with those pens.
Just making it to understand your solution, are you mean that I should save the pens in designer view & then open them in session will keep the pens intact every time opening?
Regards,
Bharat Vinchwekar
The pens will reset to what you selected and then saved in the designer. If you want to save the users selections then you will need to develop a way to store those and reload them upon returning to the view.
Thank You Daniel & Irose for the solution,
One last question, if you could help me with the same I am struggling to set the time X-axis (Time Axis) for 2 - 3 hrs instead of for a less than-minute view in the single view of the chart. Dont, know what mistake I am making too.
Below is the image of the chart I had in which I wanted to have the big time range in X-Axis.
Thanks & Regards,
Bharat Vinchwekar
Last five minutes
Tried that too but not woking for the requirement.
Hurray it worked, Thanks, Buddy....
Regards,
Bharat
