Perspective v8.1.13
I get this weird frustrating behavior with the Power Chart when panning through real time data.
This occurs in the iOS Perspective App, Microsoft Edge on iOS, and Edge on Windows10.
It doesn’t “feel” connected to mouse button events and there is clearly data to display. Checking the dev tools, I can see the line path data changing while panning. When the line gets cutoff to the left of the chart, the first point in the path is not zero. It seems a bit random, but I have seen it at -1190, 583, 200, etc. This seems to start the first point of the line either way off to the left or too far to the right of the Y axis.
Likewise, when it gets cut off at the right side, the last point’s “L” number is getting modified to a lower value than the defined chart width. For example, my chart width is 1068.87 but the last L number is 1034.88. This causes the line to not extend all the way to the extreme right of the X axis.
Me panning the chart to demonstrate how the trend lines disappear or get cut off.
Seems like a bug? Not sure if it is just me because I have not seen any chatter about it on the forum.
Did you find a solution to this?
I believe I have a similar issue. Here is one of my user’s screenshots:
And here is the same page in my browser:
He tried refreshing his page and it did not correct itself. We have seen this a decent number of times (seems intermittent). Sometimes, when you mouse-over the area with the missing data, it will show up, but not every time.
Ignition Version 8.1.44
No, I did not. I just quit using PowerChart and used XY Chart and then settled on EmbrCharts (3rd Party).
Search for Embr Charts on this forum and you will find it. @bmusson is the creator and a real swell guy!
Thanks. I’m going to submit a ticket to see if Ignition has any ideas what could be going on. If there’s no fix, I might look into that Ember Chart platform.
I just wanted to update anyone on this that may be interested.
I submitted a ticket with Ignition and found that, in my instance, this would only happen when I had tag values above 1,000,000,000 and at specific browser scale levels (125% was common for producing this effect). Interestingly, changing the line thickness to 0.5 actually solved it for me, but I also limited the tag values to below the 1,000,000,000, as this sensor data is not important for my application.
If anyone else runs into this, those may be good places to start.
