Power table and Auto Row Height offset - VISION
Good morning,
I have a power table where I query the default table "Notes". I set the wrap text for the note columns because sometimes the text is longer than the column. So I also enable the Auto Row Height to see the rows.
I don't like the result because the rows are too close to each other, should be possible to set an offset between them?
Thank you for the help.
There is an intercell spacing parameter for the power table:
Setting the height to 25 pixels produces the following result:
Correct, that is the short solution.
Thank you very much, I really missed it!
Have a nice day guys.
