on the power table is there a scripting function to auto size columns?
I see i can manually auto size the columns in the client by right clicking the header, but i want the tables columns to auto size after the window opens.
Thank you,
Thank you,
Jonathan,
Or… you can use the ‘initialize’ method on the powerTable.
powerTable.autoResizeMode = 4
This will set to auto resize on each initialization of the table. It is overkill if you set the property to begin with.
