Hey all,
Looking for some help here. Trying to set the background color of a cell based upon the cell next to it. When running the code below in the configureCell extension, it colors the entire column. Where did I go wrong?
# Configure the Size Column
if colName == 'Size':
for num in range(0,self.data.rowCount,1):
if str(self.data.getValueAt(num,0)) != "":
return {'background': '191,191,191'}
When I changed the return line to
print str(self.data.getValueAt(num,0))
then I can see the code iterating through the dataset and printing the cells that were not blank. So I am confused as to what I did wrong.
Thanks in advance.
