Hello,
I have an issue with a power table.
I changed some colors using the configureCell script function with some code like that:
from javax.swing import SwingConstants
window = system.gui.getWindow('Navigation/Home')
container = window.getRootContainer()
data = container.getComponent('Controls').data
executed = data.getValueAt(rowIndex,7)
if executed:
return {'background': 'green',
'foreground':'white'
else:
return {'background': 'white',
'foreground':'black'
The problem comes when I lunch the Client. The colors seems to belong to a Disabled component while the tables is absolutely enabled.
If I run the preview mode of the page the colors of the table are OK.
I attach two screenshots to explain it better.
Client Version
Preview
Thanks,
Federico.
