Power Table column freezing
Hello everyone,
In my project, I am using a Power Table. As more columns are added, the table becomes horizontally scrollable. The first two columns contain critical information, so they must always remain visible.
Is there a way to freeze (lock/pin) the first two columns in an Ignition Power Table so they stay visible while scrolling?
Any ideas or workarounds would be appreciated.
I am using Ignition v8.1.48
Thank you!
I think not directly. At least it is not easy.
The easiest way I found was taking 2 powertables and linking the scroll bars together. You’d have to go down to the java functions to do that though. I’ll see if i can find the exaple again.
Yes, there is a way.
Hello,
I tried working on it, but I am facing an issue: the last row gets hidden. If it is not hidden, I am unable to scroll properly. If you have any reference code for linking the scrollbars of two Power Tables in sync, could you please share it?
This is the Reference Image,
The last 26th row is Not completely visible.
