I am using a power table and have set a column to boolean so that it uses checkbox. I also have set that column as editable, under the table customizer settings. The checkbox shows properly but you can’t check or uncheck the box even though i have it set to editable. Please help!
What version are you using?
I just tested this on 7.8.2 and it does the same thing.
A workaround would be to do this in onMousePress
if colIndex==3:
curData = not value
newData = system.dataset.setValue(self.data, rowIndex, colIndex, curData)
self.data = newData
Where the colIndex points at the bool column you want to use.
Do you have the onCellEdited extension function set?
self.data = system.dataset.setValue(self.data, rowIndex, colIndex, newValue)
