Power Table - Default sorting
Is it possible to set a “Startup Default Sorting” column on the power table?
The dataset contains one timestamp column (non-sorted) that i want to sort on.
If the data is from a sql query, add an “order by” clause.
Problem is that the data is not from SQL, byt from an internal dataset.
Use the sortDataset function:
https://docs.inductiveautomation.com/display/DOC79/sortDataset
I have the same question, but I’m using Tag History on a power table. Would I have to convert to a SQL Query? If that’s the case, I would have to join different partitioned tables based on my start/end date filters, correct?
Please disregard. I figured it out.
I applied the system.dataset.sort() to the property change script.
Thanks for your input!
