Using vision, v8.0.15, I want to enable a button only if a row is selected, which is easy, but I don’t want this button enabled is multiple rows are selected. What would be the best way to accomplish this? I’m sure I could runscript, but didn’t know if there were other tricks.
You could create a custom method on the table called selectedRows() and a custom boolean property on the table named something like multipleSelected.
Put something like this in the custom method
if len(self.getSelectedRows())>1:
return 1
else:
return 0
Then in the configureCell extension function just call it and set the boolean property
self.multipleSelected = self.selectedRows()
That doesn’t really work as it won’t update unless you select rows then commit somehow, click off, etc.
Nevermind, putting in onMouseRelease should do the trick. Thanks for the help!
