Power table dynamic data edit
ignition 7.9.
Hi
I’m following these guidelines for editing an SQL db through a Power table.
https://docs.inductiveautomation.com/display/DOC79/Updating+the+Database+through+the+Power+Table
I can get it to work fine but please can someone show me how to make the table name dynamic? I want to put this table in a template so I can use it as part of a recipe editor. Ideally, I would like this to a string property on the template.
thanks.
I have solved the issue with the help of this page.
http://nickmudge.info/post/ignition-power-tables
I have an “EDIT DATA” button which uses some of the code in the above link. It iterates through the column names and builds a new column attributes table. This table contains a field called “editable”.
I also used code from the following links to create the “add row” and “delete row” buttons.
https://docs.inductiveautomation.com/display/DOC/Edit+Data+in+Database
