I tried taking data from a power table using the double click extension function and writing to tags using the writeall function but I keep getting errors, is that functionality not allowed? Thanks
[code]ERROR [AdvancedTable-AWT-EventQueue-2] Error invoking extension method.
File “”, line 34, in onDoubleClick
File “”, line 31, in populateTags
at com.inductiveautomation.ignition.client.script.ClientTagUtilities.writeToTagsImpl(ClientTagUtilities.java:303)
at com.inductiveautomation.ignition.common.script.builtin.AbstractTagUtilities.writeAll(AbstractTagUtilities.java:288)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
java.lang.Exception: java.lang.Exception: Gateway Comm Mode is not Read/Write.
at org.python.core.Py.JavaError(Py.java:495)
at com.inductiveautomation.ignition.common.script.builtin.AbstractTagUtilities.writeAll(AbstractTagUtilities.java:290)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:186)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:427)
at org.python.core.PyObject.__call__(PyObject.java:404)
at org.python.core.PyObject.__call__(PyObject.java:408)
at org.python.pycode._pyx373.populateTags$3(<extension-method onDoubleClick>:31)
at org.python.pycode._pyx373.call_function(<extension-method onDoubleClick>)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.PyBaseCode.call(PyBaseCode.java:134)
at org.python.core.PyFunction.__call__(PyFunction.java:317)
at org.python.pycode._pyx373.onDoubleClick$1(<extension-method onDoubleClick>:34)
at org.python.core.PyBaseCode.call(PyBaseCode.java:301)
at org.python.core.PyFunction.function___call__(PyFunction.java:376)
at org.python.core.PyFunction.__call__(PyFunction.java:371)
at org.python.core.PyFunction.__call__(PyFunction.java:361)
at org.python.core.PyFunction.__call__(PyFunction.java:356)
at com.inductiveautomation.vision.api.client.components.model.ExtensionFunction.invoke(ExtensionFunction.java:126)
at com.inductiveautomation.factorypmi.application.components.VisionAdvancedTable$7.onClick(VisionAdvancedTable.java:316)
at com.inductiveautomation.ignition.client.util.gui.CommonMouseAdapter.mouseReleased(CommonMouseAdapter.java:69)
at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
Caused by: java.lang.Exception: Gateway Comm Mode is not Read/Write.
… 56 more
[/code]
