Power Table Not Updating Edited Cells
Hey folks,
I have been bashing my head against this code for a week now. We are trying to make two different columns editable by users in a Power Table. For simplicity I am just trying to get one to work right now. I followed the example in the manual, but I am unable to get it to work with our database. Below I have the script we are trying to use on the table, as well as what returns in the console. Any help would be greatly appreciated.
def onCellEdited(self, rowIndex, colIndex, colName, oldValue, newValue):
	Called when the user has edited a cell in the table. It is up to the
	implementation of this function to alter the underlying data that drives
	the table. This might mean altering the dataset directly, or running a SQL
	UPDATE query to update data in a database.
	Arguments:
		self: A reference to the component that is invoking this function.
		rowIndex: Index of the row that was edited, relative to the underlying
		          dataset
		colIndex: Index of the column that was edited, relative to the
		          underlying dataset
		colName: Name of the column in the underlying dataset
		oldValue: The old value at the location, before it was edited
		newValue: The new value input by the user.
	# Example
	#self.data = system.dataset.setValue(self.data, rowIndex, colIndex, newValue)
	name = self.data.getValueAt(rowIndex, colIndex)
	query = "UPDATE TopTierPalletTracking SET %s = ? WHERE [name] = ?" % (colName)
	args = [newValue, name]
	system.db.runPrepUpdate(query, args)
	system.db.refresh(self, "data")
10:48:33.037 [AWT-EventQueue-0] ERROR Vision.Components.AdvancedTable - Error invoking extension method.
org.python.core.PyException: java.lang.Exception: java.lang.Exception: Error executing system.db.runPrepUpdate(UPDATE TopTierPalletTracking SET notes = ? WHERE [name] = ?, [test, yes], , , false, false)
at org.python.core.Py.JavaError(Py.java:547)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:362)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runPrepUpdate(AbstractDBUtilities.java:258)
at org.python.core.PyReflectedFunction.call(PyReflectedFunction.java:190)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.call(ScriptManager.java:540)
at org.python.core.PyObject.call(PyObject.java:477)
at org.python.core.PyObject.call(PyObject.java:481)
at org.python.pycode.pyx97.onCellEdited$1(:25)
at org.python.pycode.pyx97.call_function()
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.PyBaseCode.call(PyBaseCode.java:306)
at org.python.core.PyFunction.function___call
(PyFunction.java:474)
at org.python.core.PyFunction.call(PyFunction.java:469)
at org.python.core.PyFunction.call(PyFunction.java:459)
at org.python.core.PyFunction.call(PyFunction.java:454)
at com.inductiveautomation.vision.api.client.components.model.ExtensionFunction.invoke(ExtensionFunction.java:151)
at com.inductiveautomation.factorypmi.application.components.VisionAdvancedTable$Model.setValueAt(VisionAdvancedTable.java:1807)
at com.jidesoft.grid.TableModelWrapperImpl.setValueAt(Unknown Source)
at com.jidesoft.grid.DefaultTableModelWrapper.setValueAt(Unknown Source)
at java.desktop/javax.swing.JTable.setValueAt(Unknown Source)
at com.jidesoft.grid.JideTable.editingStopped(Unknown Source)
at java.desktop/javax.swing.AbstractCellEditor.fireEditingStopped(Unknown Source)
at java.desktop/javax.swing.DefaultCellEditor$EditorDelegate.stopCellEditing(Unknown Source)
at java.desktop/javax.swing.DefaultCellEditor.stopCellEditing(Unknown Source)
at java.desktop/javax.swing.DefaultCellEditor$EditorDelegate.actionPerformed(Unknown Source)
at java.desktop/javax.swing.JTextField.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.JTextField.postActionEvent(Unknown Source)
at java.desktop/javax.swing.JTextField$NotifyAction.actionPerformed(Unknown Source)
at java.desktop/javax.swing.SwingUtilities.notifyAction(Unknown Source)
at java.desktop/javax.swing.JComponent.processKeyBinding(Unknown Source)
at java.desktop/javax.swing.JComponent.processKeyBindings(Unknown Source)
at java.desktop/javax.swing.JComponent.processKeyEvent(Unknown Source)
at java.desktop/java.awt.KeyboardFocusManager.redispatchEvent(Unknown Source)
at java.desktop/java.awt.DefaultKeyboardFocusManager.dispatchKeyEvent(Unknown Source)
at java.desktop/java.awt.DefaultKeyboardFocusManager.preDispatchKeyEvent(Unknown Source)
at java.desktop/java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(Unknown Source)
at java.desktop/java.awt.DefaultKeyboardFocusManager.dispatchEvent(Unknown Source)
at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
Caused by: java.lang.Exception: Error executing system.db.runPrepUpdate(UPDATE TopTierPalletTracking SET notes = ? WHERE [name] = ?, [test, yes], , , false, false)
... 68 common frames omitted
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: SQL error for "UPDATE TopTierPalletTracking SET notes = ? WHERE [name] = ?": Invalid column name 'name'.
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:351)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:325)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:278)
at com.inductiveautomation.ignition.client.script.ClientDBUtilities._runPrepStmt(ClientDBUtilities.java:283)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runPrepUpdate(AbstractDBUtilities.java:256)
... 66 common frames omitted
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayResponse$GatewayThrowable: Invalid column name 'name'.
at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDatabaseError(SQLServerException.java:256)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.getNextResult(SQLServerStatement.java:1621)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.doExecutePreparedStatement(SQLServerPreparedStatement.java:592)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement$PrepStmtExecCmd.doExecute(SQLServerPreparedStatement.java:522)
at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:7194)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:2930)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeCommand(SQLServerStatement.java:248)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeStatement(SQLServerStatement.java:223)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.executeUpdate(SQLServerPreparedStatement.java:471)
at org.apache.commons.dbcp2.DelegatingPreparedStatement.executeUpdate(DelegatingPreparedStatement.java:136)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper$SRPreparedStatement.executeUpdate(SRConnectionWrapper.java:1016)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.RunPrepStmt.runUpdateQuery(RunPrepStmt.java:65)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.AbstractUpdateQuery.run(AbstractUpdateQuery.java:25)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.AbstractDBAction.invoke(AbstractDBAction.java:68)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:405)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:86)
at org.eclipse.jetty.servlet.ServletHolder$NotAsyncServlet.service(ServletHolder.java:1391)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:760)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:547)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:590)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1607)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1297)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:485)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1577)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1212)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:322)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:59)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:146)
at org.eclipse.jetty.server.Server.handle(Server.java:500)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:383)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:547)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:375)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:270)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:388)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:806)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:938)
at java.lang.Thread.run(null)
Check your SQL string/table column names etc... this is the error.
you're query = line isn't pulling in the name variable. It's just sending it as a string inside brackets. Swap that out for another %s...
