Power table problem
Hello,
I am doing a small power table to select a recipe by configuring the data as an SQL query like in the picture:
When I’m into designer, my vision power table works properly as intended:
But then, if I test it in Runtime, it is not working like is missing the connection:
I don’t understand the problem and I don’t understand how to solve it.
Have someone experienced something similar?
Thank you
then it should works
Hello,
thank you very much. My Fault I forgot about the proeject settings!
My fault I completely forgot to check the project settings!
Now is solved. Thank you.
