In configureCell extension function have scripted text that automaticly gets inserted to the table but it doesn’t show up in the dataset. Is there a way to get this to go in to the dataset?
That would create an infinite loop, as changes to the dataset cause all of the configure* functions to run again. You should bind your raw data to a custom property, then script or filter that in the binding to the .data property. configureCell is a presentation operation, not a data operation. (It can set up an editor, but it is not supposed to be an edit operation itself.)
