Hi all,
is it possible to set the tags in a Tag History binding of a Power Table dinamically, i.e. just when the window containing the table is opened? As far as I can understand, the only way to set those tags is per drag&drop in the binding configuration dialog:
If you are asking about indirect tag binding, yes, you can do that in Tag history binding for Power Table.
If you look just below the field that says Selected Historical Tags, you ll find “Indirection” text that you can click on.
Thanks ankitkarwa21 for your answer. No, it's not what I'm looking for: I'd like to define the list of historical tags dynamically: not only tags addresses should be dynamic, but also their number.
