Therewas an error in 7.9.7 that was mostly fixed in 7.9.8; however, it’s not 100% fixed. I have a button that, when clicked, alters a table’s dataset. It’s also gives me the following error.
The table does have the a SQL query tied to the Data property, but there is not even an option to update from there. I’ve also set the propertyChange to update a tag, and I’ve un-commented the example in the onCellEdit Extension Function
I had this error before, so I remade the table thinking that perhaps the problem carried over from the previous version (7.9.7) and that fixed it until I closed/reopened the designer. My table is still functioning as expected, but I want this popup to go away…
Anyone else run into this again?
08:28:16.554 [UpdateExecuter 2] ERROR com.inductiveautomation.factorypmi.application.gateway.QueryManager - Error running update query:
"UPDATE tablename
SET columnname = value
WHERE condition"@-1ms
On: MLs_Edit.Root Container.Parts Table.data
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: SQL error for "UPDATE tablename
WHERE condition": You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'condition' at line 3
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:341)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:315)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:268)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.runUpdateQuery(GatewayInterface.java:576)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.runUpdateQuery(GatewayInterface.java:560)
at com.inductiveautomation.factorypmi.application.gateway.QueryManager$UpdateQuery.execute(QueryManager.java:624)
at com.inductiveautomation.factorypmi.application.gateway.QueryManager$Query.execute(QueryManager.java:657)
at com.inductiveautomation.factorypmi.application.gateway.QueryManager$Query.access$500(QueryManager.java:630)
at com.inductiveautomation.factorypmi.application.gateway.QueryManager$UpdateQueryExecutor.run(QueryManager.java:425)
at java.lang.Thread.run(Unknown Source)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayResponse$GatewayThrowable: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'condition' at line 3
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(null)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(null)
at java.lang.reflect.Constructor.newInstance(null)
at com.mysql.jdbc.Util.handleNewInstance(Util.java:411)
at com.mysql.jdbc.Util.getInstance(Util.java:386)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:1053)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:4120)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:4052)
at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:2503)
at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:2664)
at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2788)
at com.mysql.jdbc.StatementImpl.executeUpdate(StatementImpl.java:1816)
at com.mysql.jdbc.StatementImpl.executeUpdate(StatementImpl.java:1730)
at org.apache.commons.dbcp.DelegatingStatement.executeUpdate(DelegatingStatement.java:228)
at com.inductiveautomation.ignition.gateway.datasource.DelegatingStatement.executeUpdate(DelegatingStatement.java:80)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper$SRStatement.executeUpdate(SRConnectionWrapper.java:857)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.RunUpdateQuery.runUpdateQuery(RunUpdateQuery.java:35)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.AbstractUpdateQuery.run(AbstractUpdateQuery.java:37)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.AbstractDBAction.invoke(AbstractDBAction.java:77)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:405)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:85)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:837)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:583)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1160)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:511)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1092)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:52)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134)
at org.eclipse.jetty.server.Server.handle(Server.java:518)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:308)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:244)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:273)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:95)
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93)
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceAndRun(ExecuteProduceConsume.java:246)
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:156)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:654)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:572)
at java.lang.Thread.run(null)
