Power Table whiting out text for no discernable reason?
A odd aesthetic issue I have with a power table I use to let people select items off with a checkbox, occasionally the text columns text goes white and multipel rows will be affected, though I can’t discern any deterministic pattern as to which ones. Like this -
I selected the person above Matt Tevald, and then that row and the row above it both turned white.
My configure cell script is only a one liner
return {'background': 'white'}
I don’t have any bindings on foreground color color or similar, and no other scripting that affects foreground color. Why is this happening/how can I fix it? Is there a way to manually make this table repaint after the selection, perhaps that would fix it? Anyone else experience this and find a fix?
What happens if you specify the foreground?
return {'foreground': 'black', 'background': 'white'}
As a personal preference, I’ll specify both foreground and background colors, whether I ultimately use it or not.
I can’t get it to happen again so that works as a fix, thanks. Curious why this even happened in the first place though,
There are a lot of events and other things happening under the hood. Probably with the highlight events, if selections are turned on.
Turning off row selection and reverting my configureCell script to my original also worked, so it was definitely a highlighting issue. Thanks.
