Power Table - Write bidirectional tags
What is the procedure for bidirectional binding in a power table? I linked the PLC tags in the cell updated property binding and chose the editable option in the table customizer. Nevertheless, when I tried to change the value in the cell it didn't work.
Thanks!
No such thing. You have to use the onCellEdited event and script the write back.
I have this working using the hidden Column with Tag Path method. Was wondering, though. With a Cell Update Binding for the Column of Values I'm changing, can the tagpath of that binding be obtained instead of using a hidden column?
