I am using the Power Chart to trend a tag value history, with setpoint ranges.
I am using a UDT, that takes in a Analog input value, and if the tag value is in any of these ranges, it will be historized.
If the tag value isnt in range, I set the value to -9999, then set the range of the axis to 0-1000 to hide the negative values
I then made 5 pens on the power chart, all set to each tag history to create a Red,Yellow,Green,Yellow,Red scheme
The chart looks close but I can not get a smooth transition between the values.
Here is a pen configuration for the individual tags
"axis": "Flow meter",
"data": {
"aggregateMode": "default",
"source": "histprov:default:/tag:/ww_flow_rate/normal"
"display": {
"breakLine": true,
"interpolation": "curveStep",
"radius": 3,
"styles": {
"normal": {
"fill": {
"color": "#4FAE4C",
"opacity": 1
"stroke": {
"color": "#4FAE4C",
"dashArray": 0,
"opacity": 1,
"width": 1
"type": "area"
"enabled": true,
"name": "Water Flow Rate",
"plot": 0,
"selectable": false,
"visible": true
Does anyone know of a way to optimize this or a way to create something similar in a different component?
