Can Ignition communicate directly to AB PowerFlex 4/40 Drives equipped with ECOM (messaging?)? The Ethernet IP network also involves a Micrologix 1400. PCCC in the ECOM appears to allow for taking data to a table in the Micrologix 1400 where it could then be read by Ignition - cumbersome and less reiliable at best. Hoping for a more direct solution. Thanks.
They’re not supported by our drivers. A better route, assuming Kepware supports them, might be to have Kepware communicate with the drives and then connect Ignition to Kepware.
