configureCell has a selected argument that does follow the arrowing, so if you're saying that you want the currently selected cell to have a thick border, the code would be written like this:
#def configureCell(self, [...], colView):
if selected:
from javax.swing import BorderFactory
borderColor = system.gui.color('red')
border = BorderFactory.createMatteBorder(4, 4, 4, 4, borderColor)
return {'background': self.selectionBackground, 'border': border}
elif rowView % 2 == 0:
return {'background': 'white'}
else:
return {'background': 'lightgrey'}
Result:
However, custom properties would be needed if you are wanting the initially clicked cell to get a border and retain it while arrowing around the table.
Example:
add custom properties for clicked cells
Store the values using the onMouseClick extension function:
#def onMouseClick(self, [...], event):
self.clickedRow = rowIndex
self.clickedColumn = colIndex
self.repaint() # This is needed to make configure cell repaint the entire table
Note: This is the extension function and not the event handler. The event handler won't register the clicked event in the inner table
Clear the selected values when appropriate using the propertyChange event handler:
if event.propertyName in ['selectedRow', 'selectedColumn'] and event.newValue == -1:
event.source.clickedRow = -1
event.source.clickedColumn = -1
event.source.repaint() # Trigger configureCell extension function
Finally, in the configureCell extension function:
if rowIndex == self.clickedRow and colIndex == self.clickedColumn:
if selected:
else:
return {'border': border}
elif selected:
return {'background': self.selectionBackground}
else:
Result: after clicking cell (2, 1) and arrowing to cell (1, 2)
