# Example
#self.data = system.dataset.setValue(self.data, rowIndex, colIndex, newValue)
ndx = self.data.getValueAt(rowIndex, 'Formula')
query = "UPDATE BL1Formulas SET %s = ? WHERE Formula = ?" % (colName)
system.db.runPrepUpdate(BL1Formulas, [value,ndx],'Kens_OT')
system.db.refresh(self.data)
First step is to debug the query itself and check the gateway for error messages. Print the query, the args, and their types.
# use system.perspective.print() instead of print() if using perspective.
print query
print 'value:{}, type:{}'.format(value,type(value))
print 'ndx:{}, type:{}'.format(ndx,type(ndx))
That should probably be
Value isn’t a valid pointer in onCellEdited
