Precision on y-axis on easy chart
Is there any way to change the precision on the y-axis? Currently, what we are seeing is that the values being displayed are in the range 0.00037 and the y-axis is showing 0.004 for all ticks. We are currently using Ignition 7.9.6.
Go into chart customizer. Select the Y-Axes tab. Select the Y-Axis. At the very bottom there is a Number Format Override property. Can try setting it to something like #,##0.00000
Jae. Thanks. I thought I had looked there, but did not see the field at the bottom. It worked like a charm.
