Prespective: Add values to dropdown from tag (Query based)
Ignition_Dropdown_values Hello,
I cannot find any information on how to add values to a dropdown in Perspective using the tag (Query). This would be very helpful. I do not want to write a named query or manually add items.
Thanks,
David
Your dataset is 30x7
You use the options binding and have to and need data set to be Label and Value
SELECT col1 as ‘value’, col2 as ‘label’ FROM db.table;
https://docs.inductiveautomation.com/display/DOC80/Perspective+-+Dropdown
Check out the properties in the options portion of the componentdata
Thank you for the quick response and the pic. It does work. Thanks. Do I need to be concerned that it looks like it has an error even though it works?
Thanks.
It is a known bug. Although I thought It was remedied in one of the recent builds. Make sure value and label are lowercase too.
I believe you could also change the Return Format to json as part of the binding, and as long as the columns are label and value, it should work.
43%20AM
Thanks, I did do as lowercase.
