so I am trying to pull the previous value from a change script but I unable to use the methods or properties associated with QualifiedValues datatype I can see if I: prevV = previousValue system.perspective.print(prevV)
it returns QV[[Lcom.inductiveautomation.ignition.common.model.values.QualifiedValue;@5db0174b, Good, Thu Oct 24 12:49:52 EDT 2024]
But if i try to reference or use any of the qualified values methods it gives me this AttributeError("'NoneType' object has no attribute 'getValue'",)
This is the code that throws the error prevV = previousValue.getValue() system.perspective.print(prevV)
Are these available when you are doing a change script on a component?
I have a change script on an array of objects, sorry should have clarified earlier
I know they are available on tag changes, but I cannot see/find where you pass the flag for component property change scripts.
oh sorry, so I have a tables components that renders data depending what on what data is being passed, I also want the option for the user to change the data via change script. So I use an embedded view and referenced my table component. The data param for the embedded view I bind to an sql query(this is also where the change script is)
so the data will theoretically never be null initially
