Print 2D barcode with reporting engine
Everything is in the question. Is it possible to generate a report containing a 2D barcode?
Yes, reporting has a barcode component with support for a variety of 1 and 2d codes, including datamatrix, QR, aztec, and pdf417:
https://docs.inductiveautomation.com/display/DOC80/Report+-+Barcode
Very good. Thank you!
Does someone print SSCC-18? That seems a standard barcode format for pallet shipping…
No, the backing library we’re using for barcode generation (Google’s zxing) doesn’t support that format. If you’re comfortable with Java, you could make a new report component (following the SDK template: https://github.com/inductiveautomation/ignition-sdk-examples/tree/master/report-component) and an open source barcode library, such as barbecue.
From what I can see on google, it seems that SSCC-18 is not really a barcode format. It defined what are the informations included in the barcode.
The format is GS1-128 with is very close to CODE 128.
Nobody did that before? The application is to print a pallet barcode. I suppose we are not the first one that need to do that…
No, to my knowledge, you’re the first person to ask. You can certainly post a request on ideas.inductiveautomation.com, or ask around if someone here on the forums (perhaps for a contract) would be willing to do the requisite development. It really doesn’t look like it would be too challenging to mash up the library I linked with our reporting engine.
Actually, looking into it more, you might just need to supply the right string (including raw ASCII characters) to a Code-128 report object and it’ll output what’s technically a GS1-128/SSCC-18 barcode - the symbology is the same, the only difference is the control characters.
Yes, we do this all the time in Ignition at our company. Just write your report to encode the data properly into a Code128 barcode. SSCC-18 is just a standard encoding built on top of GS1-128 which is built on top of Code128…
OK! Thank you very much to both of you. This is exactly my understanding but I wanted to be sure.
