Print file on server
Hi there!
Ignition 7.9.2
I am trying to allow a user to click a button that will print a file on our server to their local printer. Ideally, I would like to allow the user to be able to use the regular file dialog in order to print the file. How can I do this?
I know that the PDFViewer component has this function built in, but this component incorrectly formats my PDF. I have already contacted Ignition about this issue with formatting and they said they would have a fix by 7.9.5. Until then, I need a workaround.
Does system.print.createPrintJob do what you need?
Can system.print.createPrintJob print a PDF, using the file and not the PDF Viewer?
Perhaps you can put the pdf in a network share on the server, and then use a subprocess to open the PDF in the standard PDF reader on the clients.
See https://docs.python.org/2/library/subprocess.html on how to spawn external processes
