Print out screens for use in manual
Is there any easy way to print out all the screens within a project? Also my customer has asked for this while the machine is in a container on the Pacific Ocean somewhere, so is there a way to print the screens out whilst having no connection to a controller?
They are wanting the screen images to form part of their operational manual.
You can write a script to open each window and use this to capture it
Is this function available only in ignition 8 ?
Here is link for creating screenshots of project windows so they can be saved/printed. I have used it and it does work, although you may have to alter it slightly to fit your needs.
No, system.print.printToImage has existed in Vision for a long time. There’s no equivalent replacement for Perspective, at least at present.
But the document link given says ignition 8 ! Hence the confusion!
…Yes, because it’s in the 8.0 manual, because Vision still exists and is perfectly usable in 8.0.
I took version 8 as perspective ! Thanks for clarification
