Print Screen Button
I’m having trouble with getting the print script to work,
job = system.print.createPrintJob(event.source.parent)
job.setShowPrintDialog(0)
job.print()
I’m running this script from within a configured event on a momentary.
I get the following error when I use the button in the designer preview mode:
Error running action ‘dom.onMouseDown’ on project/site/area/Processing Statistics/Components/PrinterButton@D$0:1/root/Button: AttributeError: ‘com.inductiveautomation.ignition.common.script.Imm’ object has no attribute ‘print’
Regards,
That function is Vision Client scope only, you can’t use it in Perspective.
I’m not sure if it’s possible to capture a screenshot and print it from Perspective.
Thanks for your response,
Does that include a control+P type function? where the operators need to print to PDF or a local printer.
Regards,
They can hit ctrl-P and let the browser print.
hahaha, that’s a fair point.
But I’m changing over a brownfields site from Factory Talk and they want the exact same functionality.
Vision may have been a better choice for 1:1 functionality. Building for the browser is a very different paradigm.
Don’t hold your breath waiting for this. Browser security pretty much prohibits anything like it. Maybe possible in the future in Perspective Workstation.
