Print screen in keystroke
when i try to create print job on keystroke script is not working. There error message “name ‘event’ is not defined” . here is the my script
job = system.print.createPrintJob(event.source.parent)
job.print()
Where are you monitoring your keystroke?
I’m guessing you’re using a Keystroke Client Event Script. Something like this should work for you:
window = system.gui.getWindow("Your Window").getRootContainer()
job = system.print.createPrintJob(window)
job.print()
Thanks ethomason, The print job worked.
