I’m trying to get printer status from a label printer with C# API. Need some advice on how to connect and read data directly from Ignition - if possible?
Ignition is not written in .NET so this library/API is not directly useful.
You might be able to use it to build a small .NET web service that you can communicate with from Ignition, that in turn communicates with the label printer.
Don’t expect the c# code to be easy. Learn the language of ZPL. You’ll find it easy to do if you can get your hands on one sample zpl file with the commands to encode it. In order to add more details to an existing mark, I literally had to learn this two days ago to change zpl. The zpl language is pretty easy to understand and with a printer you can do all your tests on a notepad.
