Printing a number of copies
In the system.print.createPrintJob function, it seems I can pass most arguments to the job that can also be set in the printer dialog.
However, I don’t seem able to set the number of copies. I want to calculate the number of boxes based on the weight, and then print the same sheet for every box produced to accompany it.
Is there some way I can achieve this? java.awt.print.PrinterJob does seem to have such a function available. Can I get in from the Ignition printerjob to the awt printer job, or is there some other base class used?
Printing the sheets in a loop seems tedious, as I want to also provide an option for when the default printer is offline, so they can select a different printer. If I loop, I either can’t pass the number of copies, or I get a huge number of print dialogs.
This example prints 4 copies only showing the dialog once.
printJob = system.print.createPrintJob(self.parent.getComponent('Power Table'))
printJob.print()
# Stop printing if user pressed cancel!
if printJob..getPrinterName():
	printJob.setShowPrintDialog(False)
	for i in range(3):
		printJob.print()
I’m curious if this works:
printJob.copies = 4
printJob.print()
AttributeError: 'com.inductiveautomation.factorypmi.application.scr' object has no attribute 'copies'
Womp womp.
Just realized my previous post doesn’t work as expected :slight_smile:
This code does however. The example prints a power table component. You might need to modify a little to print something else.
	from javax.swing.JTable import PrintMode
	from javax.print.attribute import HashPrintRequestAttributeSet
	from javax.print.attribute.standard import Copies
	from java.awt.print import PrinterJob
	printable = self.parent.getComponent('Power Table').getTable().getPrintable(PrintMode.FIT_WIDTH, None, None)
	job = PrinterJob.getPrinterJob()
	job.setPrintable(printable)
	aset = HashPrintRequestAttributeSet();
	aset.add(Copies(2))
	job.printDialog(aset) # Or just job.print(aset) to print without the dialog.
Apparently, getting the printable of a different component is a bit harder, but we can (ab)use some code prepared by IA: http://files.inductiveautomation.com/sdk/javadoc/ignition79/790-beta1/index.html
Apart from that, you always need to execute print() after printDialog(), as printDialog only seems to modify the aset, and return True when the user chose to print.
Then I added some other options, like the possibility to select a default printer, and changing the orientation.
from javax.print.attribute.standard import OrientationRequested
from com.inductiveautomation.factorypmi.application.script.builtin.PrintUtilities import ComponentPrinter
printable = ComponentPrinter(event.source.parent.getComponent('Container'), True, 1)
aset.add(Copies(2))
aset.add(OrientationRequested.LANDSCAPE);
services = job.lookupPrintServices()
print [s.getName() for s in services] # find the correct service in the list to select a printer
job.setPrintService(services[8])
if job.printDialog(aset):
	job.print(aset)
Thanks for all the help :+1:
Not on my system, this did send the print job to the printer selected :slight_smile:
No problem :thumbsup:
