Update from Ignition 7.9 to 8.1.5, gateway not running
Mmm, are you sure the installer ran and you did an upgrade?
You seem to be looking at a 7.9 gateway according to both the version and the fact that the GCU does not exist in 8.0+.
Can you share the wrapper log files here? You should be able to find them in the $IGNITION/logs directory.
Sorry, i cant upload the file, this wrote when we installed it
STATUS | wrapperm | 2021/05/13 08:42:33 | The Ignition Gateway Service is installed.
STATUS | wrapperm | 2021/05/13 08:42:33 | Start Type: Automatic
STATUS | wrapperm | 2021/05/13 08:42:33 | Interactive: No
STATUS | wrapperm | 2021/05/13 08:42:33 | Running: Yes
INFO | jvm 1 | 2021/05/13 08:42:35 | E [d.T.TCPConnection[9004] ] [13:42:35]: Error connecting to 10.60.78.171:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:42:43 | I [O.DAServer[Matrikon OPC Omron]] [13:42:43]: Server 'Matrikon OPC Omron' state set to [CONNECTING]
INFO | jvm 1 | 2021/05/13 08:42:43 | I [O.DAServer[Matrikon OPC Omron]] [13:42:43]: Attempting to connect COM server 'Matrikon OPC Omron'
INFO | jvm 1 | 2021/05/13 08:42:43 | E [O.DAServer[Matrikon OPC Omron]] [13:42:43]: Error connecting OPC-COM server.
INFO | jvm 1 | 2021/05/13 08:42:43 | com.jniwrapper.win32.com.ComException: COM object method returns error code: 0x800700A4; No more threads can be created in the system.
INFO | jvm 1 | 2021/05/13 08:42:43 | at com.jniwrapper.win32.com.ComException.checkResult(SourceFile:172)
INFO | jvm 1 | 2021/05/13 08:42:43 | at com.jniwrapper.win32.com.ComFunctions.coCreateInstanceEx(SourceFile:230)
INFO | jvm 1 | 2021/05/13 08:42:43 | at com.inductiveautomation.opccom.COMServerImpl$ConnectServerJob.internalRun(COMServerImpl.java:662)
INFO | jvm 1 | 2021/05/13 08:42:43 | at com.inductiveautomation.opccom.wrapper.OleJob.run(OleJob.java:48)
INFO | jvm 1 | 2021/05/13 08:42:43 | at com.jniwrapper.win32.MessageLoopThread$ThreadSynchronizedAction.run(MessageLoopThread.java:620)
INFO | jvm 1 | 2021/05/13 08:42:43 | at com.jniwrapper.win32.MessageLoopThread$LoopThread.run(MessageLoopThread.java:562)
INFO | jvm 1 | 2021/05/13 08:42:43 | I [O.DAServer[Matrikon OPC Omron]] [13:42:43]: Disconnecting server 'Matrikon OPC Omron', healthy: false
INFO | jvm 1 | 2021/05/13 08:42:43 | I [O.DAServer[Matrikon OPC Omron]] [13:42:43]: Server 'Matrikon OPC Omron' state set to [CLOSED]
INFO | jvm 1 | 2021/05/13 08:42:43 | I [c.i.o.w.s.COMSubscription ] [13:42:43]: Shutting down subscription 'Scanclass 'Default[default]''. Is healthy shutdown: false
INFO | jvm 1 | 2021/05/13 08:42:43 | I [c.i.o.w.s.COMSubscription ] [13:42:43]: Shutting down subscription 'Scanclass 'Fast Scan[default]''. Is healthy shutdown: false
INFO | jvm 1 | 2021/05/13 08:42:43 | I [O.DAServer[Matrikon OPC Omron]] [13:42:43]: Server 'Matrikon OPC Omron' state set to [FAULTED]
INFO | jvm 1 | 2021/05/13 08:42:45 | E [d.T.TCPConnection[9004] ] [13:42:45]: Error connecting to 10.60.76.105:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:42:45 | E [d.T.TCPConnection[9004] ] [13:42:45]: Error connecting to 10.60.76.66:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:42:47 | E [d.T.TCPConnection[9004] ] [13:42:47]: Error connecting to 10.60.78.172:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:42:54 | E [d.T.TCPConnection[9004] ] [13:42:54]: Error connecting to 10.60.76.174:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:42:54 | E [d.T.TCPConnection[9004] ] [13:42:54]: Error connecting to 10.60.77.87:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:42:55 | E [d.T.TCPConnection[9004] ] [13:42:55]: Error connecting to 10.59.7.240:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:43:43 | I [O.DAServer[Matrikon OPC Omron]] [13:43:43]: Server 'Matrikon OPC Omron' state set to [CONNECTING]
INFO | jvm 1 | 2021/05/13 08:43:43 | I [O.DAServer[Matrikon OPC Omron]] [13:43:43]: Attempting to connect COM server 'Matrikon OPC Omron'
INFO | jvm 1 | 2021/05/13 08:43:43 | E [O.DAServer[Matrikon OPC Omron]] [13:43:43]: Error connecting OPC-COM server.
INFO | jvm 1 | 2021/05/13 08:43:43 | com.jniwrapper.win32.com.ComException: COM object method returns error code: 0x800700A4; No more threads can be created in the system.
INFO | jvm 1 | 2021/05/13 08:43:43 | at com.jniwrapper.win32.com.ComException.checkResult(SourceFile:172)
INFO | jvm 1 | 2021/05/13 08:43:43 | at com.jniwrapper.win32.com.ComFunctions.coCreateInstanceEx(SourceFile:230)
INFO | jvm 1 | 2021/05/13 08:43:43 | at com.inductiveautomation.opccom.COMServerImpl$ConnectServerJob.internalRun(COMServerImpl.java:662)
INFO | jvm 1 | 2021/05/13 08:43:43 | at com.inductiveautomation.opccom.wrapper.OleJob.run(OleJob.java:48)
INFO | jvm 1 | 2021/05/13 08:43:43 | at com.jniwrapper.win32.MessageLoopThread$ThreadSynchronizedAction.run(MessageLoopThread.java:620)
INFO | jvm 1 | 2021/05/13 08:43:43 | at com.jniwrapper.win32.MessageLoopThread$LoopThread.run(MessageLoopThread.java:562)
INFO | jvm 1 | 2021/05/13 08:43:43 | I [O.DAServer[Matrikon OPC Omron]] [13:43:43]: Disconnecting server 'Matrikon OPC Omron', healthy: false
INFO | jvm 1 | 2021/05/13 08:43:43 | I [O.DAServer[Matrikon OPC Omron]] [13:43:43]: Server 'Matrikon OPC Omron' state set to [CLOSED]
INFO | jvm 1 | 2021/05/13 08:43:43 | I [c.i.o.w.s.COMSubscription ] [13:43:43]: Shutting down subscription 'Scanclass 'Default[default]''. Is healthy shutdown: false
INFO | jvm 1 | 2021/05/13 08:43:43 | I [c.i.o.w.s.COMSubscription ] [13:43:43]: Shutting down subscription 'Scanclass 'Fast Scan[default]''. Is healthy shutdown: false
INFO | jvm 1 | 2021/05/13 08:43:43 | I [O.DAServer[Matrikon OPC Omron]] [13:43:43]: Server 'Matrikon OPC Omron' state set to [FAULTED]
INFO | jvm 1 | 2021/05/13 08:43:47 | E [d.T.TCPConnection[9004] ] [13:43:47]: Error connecting to 10.60.78.171:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:43:53 | E [d.T.TCPConnection[9004] ] [13:43:53]: Error connecting to 10.60.78.172:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:43:57 | E [d.T.TCPConnection[9004] ] [13:43:57]: Error connecting to 10.60.76.105:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:43:57 | E [d.T.TCPConnection[9004] ] [13:43:57]: Error connecting to 10.60.76.66:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:44:06 | E [d.T.TCPConnection[9004] ] [13:44:06]: Error connecting to 10.60.76.174:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:44:06 | E [d.T.TCPConnection[9004] ] [13:44:06]: Error connecting to 10.60.77.87:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:44:07 | E [d.T.TCPConnection[9004] ] [13:44:07]: Error connecting to 10.59.7.240:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:44:43 | I [O.DAServer[Matrikon OPC Omron]] [13:44:43]: Server 'Matrikon OPC Omron' state set to [CONNECTING]
INFO | jvm 1 | 2021/05/13 08:44:43 | I [O.DAServer[Matrikon OPC Omron]] [13:44:43]: Attempting to connect COM server 'Matrikon OPC Omron'
INFO | jvm 1 | 2021/05/13 08:44:43 | E [O.DAServer[Matrikon OPC Omron]] [13:44:43]: Error connecting OPC-COM server.
INFO | jvm 1 | 2021/05/13 08:44:43 | com.jniwrapper.win32.com.ComException: COM object method returns error code: 0x800700A4; No more threads can be created in the system.
INFO | jvm 1 | 2021/05/13 08:44:43 | at com.jniwrapper.win32.com.ComException.checkResult(SourceFile:172)
INFO | jvm 1 | 2021/05/13 08:44:43 | at com.jniwrapper.win32.com.ComFunctions.coCreateInstanceEx(SourceFile:230)
INFO | jvm 1 | 2021/05/13 08:44:43 | at com.inductiveautomation.opccom.COMServerImpl$ConnectServerJob.internalRun(COMServerImpl.java:662)
INFO | jvm 1 | 2021/05/13 08:44:43 | at com.inductiveautomation.opccom.wrapper.OleJob.run(OleJob.java:48)
INFO | jvm 1 | 2021/05/13 08:44:43 | at com.jniwrapper.win32.MessageLoopThread$ThreadSynchronizedAction.run(MessageLoopThread.java:620)
INFO | jvm 1 | 2021/05/13 08:44:43 | at com.jniwrapper.win32.MessageLoopThread$LoopThread.run(MessageLoopThread.java:562)
INFO | jvm 1 | 2021/05/13 08:44:43 | I [O.DAServer[Matrikon OPC Omron]] [13:44:43]: Disconnecting server 'Matrikon OPC Omron', healthy: false
INFO | jvm 1 | 2021/05/13 08:44:43 | I [O.DAServer[Matrikon OPC Omron]] [13:44:43]: Server 'Matrikon OPC Omron' state set to [CLOSED]
INFO | jvm 1 | 2021/05/13 08:44:43 | I [c.i.o.w.s.COMSubscription ] [13:44:43]: Shutting down subscription 'Scanclass 'Default[default]''. Is healthy shutdown: false
INFO | jvm 1 | 2021/05/13 08:44:43 | I [c.i.o.w.s.COMSubscription ] [13:44:43]: Shutting down subscription 'Scanclass 'Fast Scan[default]''. Is healthy shutdown: false
INFO | jvm 1 | 2021/05/13 08:44:43 | I [O.DAServer[Matrikon OPC Omron]] [13:44:43]: Server 'Matrikon OPC Omron' state set to [FAULTED]
INFO | jvm 1 | 2021/05/13 08:44:59 | E [d.T.TCPConnection[9004] ] [13:44:59]: Error connecting to 10.60.78.171:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:45:03 | E [d.T.TCPConnection[9004] ] [13:45:03]: Error connecting to 10.60.76.66:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:45:05 | E [d.T.TCPConnection[9004] ] [13:45:05]: Error connecting to 10.60.78.172:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:45:09 | E [d.T.TCPConnection[9004] ] [13:45:09]: Error connecting to 10.60.76.105:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:45:13 | E [d.T.TCPConnection[9004] ] [13:45:13]: Error connecting to 10.59.7.240:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:45:18 | E [d.T.TCPConnection[9004] ] [13:45:18]: Error connecting to 10.60.76.174:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:45:18 | E [d.T.TCPConnection[9004] ] [13:45:18]: Error connecting to 10.60.77.87:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:45:43 | I [O.DAServer[Matrikon OPC Omron]] [13:45:43]: Server 'Matrikon OPC Omron' state set to [CONNECTING]
INFO | jvm 1 | 2021/05/13 08:45:43 | I [O.DAServer[Matrikon OPC Omron]] [13:45:43]: Attempting to connect COM server 'Matrikon OPC Omron'
INFO | jvm 1 | 2021/05/13 08:45:43 | E [O.DAServer[Matrikon OPC Omron]] [13:45:43]: Error connecting OPC-COM server.
INFO | jvm 1 | 2021/05/13 08:45:43 | com.jniwrapper.win32.com.ComException: COM object method returns error code: 0x800700A4; No more threads can be created in the system.
INFO | jvm 1 | 2021/05/13 08:45:43 | at com.jniwrapper.win32.com.ComException.checkResult(SourceFile:172)
INFO | jvm 1 | 2021/05/13 08:45:43 | at com.jniwrapper.win32.com.ComFunctions.coCreateInstanceEx(SourceFile:230)
INFO | jvm 1 | 2021/05/13 08:45:43 | at com.inductiveautomation.opccom.COMServerImpl$ConnectServerJob.internalRun(COMServerImpl.java:662)
INFO | jvm 1 | 2021/05/13 08:45:43 | at com.inductiveautomation.opccom.wrapper.OleJob.run(OleJob.java:48)
INFO | jvm 1 | 2021/05/13 08:45:43 | at com.jniwrapper.win32.MessageLoopThread$ThreadSynchronizedAction.run(MessageLoopThread.java:620)
INFO | jvm 1 | 2021/05/13 08:45:43 | at com.jniwrapper.win32.MessageLoopThread$LoopThread.run(MessageLoopThread.java:562)
INFO | jvm 1 | 2021/05/13 08:45:43 | I [O.DAServer[Matrikon OPC Omron]] [13:45:43]: Disconnecting server 'Matrikon OPC Omron', healthy: false
INFO | jvm 1 | 2021/05/13 08:45:43 | I [O.DAServer[Matrikon OPC Omron]] [13:45:43]: Server 'Matrikon OPC Omron' state set to [CLOSED]
INFO | jvm 1 | 2021/05/13 08:45:43 | I [c.i.o.w.s.COMSubscription ] [13:45:43]: Shutting down subscription 'Scanclass 'Default[default]''. Is healthy shutdown: false
INFO | jvm 1 | 2021/05/13 08:45:43 | I [c.i.o.w.s.COMSubscription ] [13:45:43]: Shutting down subscription 'Scanclass 'Fast Scan[default]''. Is healthy shutdown: false
INFO | jvm 1 | 2021/05/13 08:45:43 | I [O.DAServer[Matrikon OPC Omron]] [13:45:43]: Server 'Matrikon OPC Omron' state set to [FAULTED]
INFO | jvm 1 | 2021/05/13 08:46:05 | E [d.T.TCPConnection[9004] ] [13:46:05]: Error connecting to 10.60.78.171:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:46:15 | E [d.T.TCPConnection[9004] ] [13:46:15]: Error connecting to 10.60.76.105:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:46:15 | E [d.T.TCPConnection[9004] ] [13:46:15]: Error connecting to 10.60.76.66:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:46:18 | E [d.T.TCPConnection[9004] ] [13:46:17]: Error connecting to 10.60.78.172:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:46:24 | E [d.T.TCPConnection[9004] ] [13:46:24]: Error connecting to 10.60.76.174:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:46:24 | E [d.T.TCPConnection[9004] ] [13:46:24]: Error connecting to 10.60.77.87:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:46:26 | E [d.T.TCPConnection[9004] ] [13:46:25]: Error connecting to 10.59.7.240:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:46:43 | I [O.DAServer[Matrikon OPC Omron]] [13:46:43]: Server 'Matrikon OPC Omron' state set to [CONNECTING]
INFO | jvm 1 | 2021/05/13 08:46:43 | I [O.DAServer[Matrikon OPC Omron]] [13:46:43]: Attempting to connect COM server 'Matrikon OPC Omron'
INFO | jvm 1 | 2021/05/13 08:46:43 | E [O.DAServer[Matrikon OPC Omron]] [13:46:43]: Error connecting OPC-COM server.
INFO | jvm 1 | 2021/05/13 08:46:43 | com.jniwrapper.win32.com.ComException: COM object method returns error code: 0x800700A4; No more threads can be created in the system.
INFO | jvm 1 | 2021/05/13 08:46:43 | at com.jniwrapper.win32.com.ComException.checkResult(SourceFile:172)
INFO | jvm 1 | 2021/05/13 08:46:43 | at com.jniwrapper.win32.com.ComFunctions.coCreateInstanceEx(SourceFile:230)
INFO | jvm 1 | 2021/05/13 08:46:43 | at com.inductiveautomation.opccom.COMServerImpl$ConnectServerJob.internalRun(COMServerImpl.java:662)
INFO | jvm 1 | 2021/05/13 08:46:43 | at com.inductiveautomation.opccom.wrapper.OleJob.run(OleJob.java:48)
INFO | jvm 1 | 2021/05/13 08:46:43 | at com.jniwrapper.win32.MessageLoopThread$ThreadSynchronizedAction.run(MessageLoopThread.java:620)
INFO | jvm 1 | 2021/05/13 08:46:43 | at com.jniwrapper.win32.MessageLoopThread$LoopThread.run(MessageLoopThread.java:562)
INFO | jvm 1 | 2021/05/13 08:46:43 | I [O.DAServer[Matrikon OPC Omron]] [13:46:43]: Disconnecting server 'Matrikon OPC Omron', healthy: false
INFO | jvm 1 | 2021/05/13 08:46:43 | I [O.DAServer[Matrikon OPC Omron]] [13:46:43]: Server 'Matrikon OPC Omron' state set to [CLOSED]
INFO | jvm 1 | 2021/05/13 08:46:43 | I [c.i.o.w.s.COMSubscription ] [13:46:43]: Shutting down subscription 'Scanclass 'Default[default]''. Is healthy shutdown: false
INFO | jvm 1 | 2021/05/13 08:46:43 | I [c.i.o.w.s.COMSubscription ] [13:46:43]: Shutting down subscription 'Scanclass 'Fast Scan[default]''. Is healthy shutdown: false
INFO | jvm 1 | 2021/05/13 08:46:43 | I [O.DAServer[Matrikon OPC Omron]] [13:46:43]: Server 'Matrikon OPC Omron' state set to [FAULTED]
INFO | jvm 1 | 2021/05/13 08:47:17 | E [d.T.TCPConnection[9004] ] [13:47:17]: Error connecting to 10.60.78.171:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:47:24 | E [d.T.TCPConnection[9004] ] [13:47:24]: Error connecting to 10.60.78.172:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:47:27 | E [d.T.TCPConnection[9004] ] [13:47:27]: Error connecting to 10.60.76.105:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:47:27 | E [d.T.TCPConnection[9004] ] [13:47:27]: Error connecting to 10.60.76.66:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:47:36 | E [d.T.TCPConnection[9004] ] [13:47:36]: Error connecting to 10.60.76.174:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:47:36 | E [d.T.TCPConnection[9004] ] [13:47:36]: Error connecting to 10.60.77.87:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:47:38 | E [d.T.TCPConnection[9004] ] [13:47:38]: Error connecting to 10.59.7.240:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:47:43 | I [O.DAServer[Matrikon OPC Omron]] [13:47:43]: Server 'Matrikon OPC Omron' state set to [CONNECTING]
INFO | jvm 1 | 2021/05/13 08:47:43 | I [O.DAServer[Matrikon OPC Omron]] [13:47:43]: Attempting to connect COM server 'Matrikon OPC Omron'
INFO | jvm 1 | 2021/05/13 08:47:43 | E [O.DAServer[Matrikon OPC Omron]] [13:47:43]: Error connecting OPC-COM server.
INFO | jvm 1 | 2021/05/13 08:47:43 | com.jniwrapper.win32.com.ComException: COM object method returns error code: 0x800700A4; No more threads can be created in the system.
INFO | jvm 1 | 2021/05/13 08:47:43 | at com.jniwrapper.win32.com.ComException.checkResult(SourceFile:172)
INFO | jvm 1 | 2021/05/13 08:47:43 | at com.jniwrapper.win32.com.ComFunctions.coCreateInstanceEx(SourceFile:230)
INFO | jvm 1 | 2021/05/13 08:47:43 | at com.inductiveautomation.opccom.COMServerImpl$ConnectServerJob.internalRun(COMServerImpl.java:662)
INFO | jvm 1 | 2021/05/13 08:47:43 | at com.inductiveautomation.opccom.wrapper.OleJob.run(OleJob.java:48)
INFO | jvm 1 | 2021/05/13 08:47:43 | at com.jniwrapper.win32.MessageLoopThread$ThreadSynchronizedAction.run(MessageLoopThread.java:620)
INFO | jvm 1 | 2021/05/13 08:47:43 | at com.jniwrapper.win32.MessageLoopThread$LoopThread.run(MessageLoopThread.java:562)
INFO | jvm 1 | 2021/05/13 08:47:43 | I [O.DAServer[Matrikon OPC Omron]] [13:47:43]: Disconnecting server 'Matrikon OPC Omron', healthy: false
INFO | jvm 1 | 2021/05/13 08:47:43 | I [O.DAServer[Matrikon OPC Omron]] [13:47:43]: Server 'Matrikon OPC Omron' state set to [CLOSED]
INFO | jvm 1 | 2021/05/13 08:47:43 | I [c.i.o.w.s.COMSubscription ] [13:47:43]: Shutting down subscription 'Scanclass 'Default[default]''. Is healthy shutdown: false
INFO | jvm 1 | 2021/05/13 08:47:43 | I [c.i.o.w.s.COMSubscription ] [13:47:43]: Shutting down subscription 'Scanclass 'Fast Scan[default]''. Is healthy shutdown: false
INFO | jvm 1 | 2021/05/13 08:47:43 | I [O.DAServer[Matrikon OPC Omron]] [13:47:43]: Server 'Matrikon OPC Omron' state set to [FAULTED]
INFO | jvm 1 | 2021/05/13 08:48:29 | E [d.T.TCPConnection[9004] ] [13:48:29]: Error connecting to 10.60.78.171:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:48:33 | E [d.T.TCPConnection[9004] ] [13:48:33]: Error connecting to 10.60.76.105:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:48:33 | E [d.T.TCPConnection[9004] ] [13:48:33]: Error connecting to 10.60.76.66:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:48:36 | E [d.T.TCPConnection[9004] ] [13:48:36]: Error connecting to 10.60.78.172:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:48:43 | I [O.DAServer[Matrikon OPC Omron]] [13:48:43]: Server 'Matrikon OPC Omron' state set to [CONNECTING]
INFO | jvm 1 | 2021/05/13 08:48:43 | I [O.DAServer[Matrikon OPC Omron]] [13:48:43]: Attempting to connect COM server 'Matrikon OPC Omron'
INFO | jvm 1 | 2021/05/13 08:48:43 | E [O.DAServer[Matrikon OPC Omron]] [13:48:43]: Error connecting OPC-COM server.
INFO | jvm 1 | 2021/05/13 08:48:43 | com.jniwrapper.win32.com.ComException: COM object method returns error code: 0x800700A4; No more threads can be created in the system.
INFO | jvm 1 | 2021/05/13 08:48:43 | at com.jniwrapper.win32.com.ComException.checkResult(SourceFile:172)
INFO | jvm 1 | 2021/05/13 08:48:43 | at com.jniwrapper.win32.com.ComFunctions.coCreateInstanceEx(SourceFile:230)
INFO | jvm 1 | 2021/05/13 08:48:43 | at com.inductiveautomation.opccom.COMServerImpl$ConnectServerJob.internalRun(COMServerImpl.java:662)
INFO | jvm 1 | 2021/05/13 08:48:43 | at com.inductiveautomation.opccom.wrapper.OleJob.run(OleJob.java:48)
INFO | jvm 1 | 2021/05/13 08:48:43 | at com.jniwrapper.win32.MessageLoopThread$ThreadSynchronizedAction.run(MessageLoopThread.java:620)
INFO | jvm 1 | 2021/05/13 08:48:43 | at com.jniwrapper.win32.MessageLoopThread$LoopThread.run(MessageLoopThread.java:562)
INFO | jvm 1 | 2021/05/13 08:48:43 | I [O.DAServer[Matrikon OPC Omron]] [13:48:43]: Disconnecting server 'Matrikon OPC Omron', healthy: false
INFO | jvm 1 | 2021/05/13 08:48:43 | I [O.DAServer[Matrikon OPC Omron]] [13:48:43]: Server 'Matrikon OPC Omron' state set to [CLOSED]
INFO | jvm 1 | 2021/05/13 08:48:43 | I [c.i.o.w.s.COMSubscription ] [13:48:43]: Shutting down subscription 'Scanclass 'Default[default]''. Is healthy shutdown: false
INFO | jvm 1 | 2021/05/13 08:48:43 | I [c.i.o.w.s.COMSubscription ] [13:48:43]: Shutting down subscription 'Scanclass 'Fast Scan[default]''. Is healthy shutdown: false
INFO | jvm 1 | 2021/05/13 08:48:43 | I [O.DAServer[Matrikon OPC Omron]] [13:48:43]: Server 'Matrikon OPC Omron' state set to [FAULTED]
INFO | jvm 1 | 2021/05/13 08:48:44 | E [d.T.TCPConnection[9004] ] [13:48:44]: Error connecting to 10.59.7.240:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:48:48 | E [d.T.TCPConnection[9004] ] [13:48:48]: Error connecting to 10.60.76.174:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:48:48 | E [d.T.TCPConnection[9004] ] [13:48:48]: Error connecting to 10.60.77.87:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:49:35 | E [d.T.TCPConnection[9004] ] [13:49:35]: Error connecting to 10.60.78.171:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:49:43 | I [O.DAServer[Matrikon OPC Omron]] [13:49:43]: Server 'Matrikon OPC Omron' state set to [CONNECTING]
INFO | jvm 1 | 2021/05/13 08:49:43 | I [O.DAServer[Matrikon OPC Omron]] [13:49:43]: Attempting to connect COM server 'Matrikon OPC Omron'
INFO | jvm 1 | 2021/05/13 08:49:43 | E [O.DAServer[Matrikon OPC Omron]] [13:49:43]: Error connecting OPC-COM server.
INFO | jvm 1 | 2021/05/13 08:49:43 | com.jniwrapper.win32.com.ComException: COM object method returns error code: 0x800700A4; No more threads can be created in the system.
INFO | jvm 1 | 2021/05/13 08:49:43 | at com.jniwrapper.win32.com.ComException.checkResult(SourceFile:172)
INFO | jvm 1 | 2021/05/13 08:49:43 | at com.jniwrapper.win32.com.ComFunctions.coCreateInstanceEx(SourceFile:230)
INFO | jvm 1 | 2021/05/13 08:49:43 | at com.inductiveautomation.opccom.COMServerImpl$ConnectServerJob.internalRun(COMServerImpl.java:662)
INFO | jvm 1 | 2021/05/13 08:49:43 | at com.inductiveautomation.opccom.wrapper.OleJob.run(OleJob.java:48)
INFO | jvm 1 | 2021/05/13 08:49:43 | at com.jniwrapper.win32.MessageLoopThread$ThreadSynchronizedAction.run(MessageLoopThread.java:620)
INFO | jvm 1 | 2021/05/13 08:49:43 | at com.jniwrapper.win32.MessageLoopThread$LoopThread.run(MessageLoopThread.java:562)
INFO | jvm 1 | 2021/05/13 08:49:43 | I [O.DAServer[Matrikon OPC Omron]] [13:49:43]: Disconnecting server 'Matrikon OPC Omron', healthy: false
INFO | jvm 1 | 2021/05/13 08:49:43 | I [O.DAServer[Matrikon OPC Omron]] [13:49:43]: Server 'Matrikon OPC Omron' state set to [CLOSED]
INFO | jvm 1 | 2021/05/13 08:49:43 | I [c.i.o.w.s.COMSubscription ] [13:49:43]: Shutting down subscription 'Scanclass 'Default[default]''. Is healthy shutdown: false
INFO | jvm 1 | 2021/05/13 08:49:43 | I [c.i.o.w.s.COMSubscription ] [13:49:43]: Shutting down subscription 'Scanclass 'Fast Scan[default]''. Is healthy shutdown: false
INFO | jvm 1 | 2021/05/13 08:49:43 | I [O.DAServer[Matrikon OPC Omron]] [13:49:43]: Server 'Matrikon OPC Omron' state set to [FAULTED]
INFO | jvm 1 | 2021/05/13 08:49:45 | E [d.T.TCPConnection[9004] ] [13:49:45]: Error connecting to 10.60.76.105:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:49:46 | E [d.T.TCPConnection[9004] ] [13:49:45]: Error connecting to 10.60.76.66:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:49:48 | E [d.T.TCPConnection[9004] ] [13:49:48]: Error connecting to 10.60.78.172:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:49:54 | E [d.T.TCPConnection[9004] ] [13:49:54]: Error connecting to 10.60.76.174:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:49:54 | E [d.T.TCPConnection[9004] ] [13:49:54]: Error connecting to 10.60.77.87:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:49:56 | E [d.T.TCPConnection[9004] ] [13:49:56]: Error connecting to 10.59.7.240:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:50:43 | I [O.DAServer[Matrikon OPC Omron]] [13:50:43]: Server 'Matrikon OPC Omron' state set to [CONNECTING]
INFO | jvm 1 | 2021/05/13 08:50:43 | I [O.DAServer[Matrikon OPC Omron]] [13:50:43]: Attempting to connect COM server 'Matrikon OPC Omron'
INFO | jvm 1 | 2021/05/13 08:50:43 | E [O.DAServer[Matrikon OPC Omron]] [13:50:43]: Error connecting OPC-COM server.
INFO | jvm 1 | 2021/05/13 08:50:43 | com.jniwrapper.win32.com.ComException: COM object method returns error code: 0x800700A4; No more threads can be created in the system.
INFO | jvm 1 | 2021/05/13 08:50:43 | at com.jniwrapper.win32.com.ComException.checkResult(SourceFile:172)
INFO | jvm 1 | 2021/05/13 08:50:43 | at com.jniwrapper.win32.com.ComFunctions.coCreateInstanceEx(SourceFile:230)
INFO | jvm 1 | 2021/05/13 08:50:43 | at com.inductiveautomation.opccom.COMServerImpl$ConnectServerJob.internalRun(COMServerImpl.java:662)
INFO | jvm 1 | 2021/05/13 08:50:43 | at com.inductiveautomation.opccom.wrapper.OleJob.run(OleJob.java:48)
INFO | jvm 1 | 2021/05/13 08:50:43 | at com.jniwrapper.win32.MessageLoopThread$ThreadSynchronizedAction.run(MessageLoopThread.java:620)
INFO | jvm 1 | 2021/05/13 08:50:43 | at com.jniwrapper.win32.MessageLoopThread$LoopThread.run(MessageLoopThread.java:562)
INFO | jvm 1 | 2021/05/13 08:50:43 | I [O.DAServer[Matrikon OPC Omron]] [13:50:43]: Disconnecting server 'Matrikon OPC Omron', healthy: false
INFO | jvm 1 | 2021/05/13 08:50:43 | I [O.DAServer[Matrikon OPC Omron]] [13:50:43]: Server 'Matrikon OPC Omron' state set to [CLOSED]
INFO | jvm 1 | 2021/05/13 08:50:43 | I [c.i.o.w.s.COMSubscription ] [13:50:43]: Shutting down subscription 'Scanclass 'Default[default]''. Is healthy shutdown: false
INFO | jvm 1 | 2021/05/13 08:50:43 | I [c.i.o.w.s.COMSubscription ] [13:50:43]: Shutting down subscription 'Scanclass 'Fast Scan[default]''. Is healthy shutdown: false
INFO | jvm 1 | 2021/05/13 08:50:43 | I [O.DAServer[Matrikon OPC Omron]] [13:50:43]: Server 'Matrikon OPC Omron' state set to [FAULTED]
INFO | jvm 1 | 2021/05/13 08:50:47 | E [d.T.TCPConnection[9004] ] [13:50:47]: Error connecting to 10.60.78.171:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:50:54 | E [d.T.TCPConnection[9004] ] [13:50:54]: Error connecting to 10.60.78.172:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:50:57 | E [d.T.TCPConnection[9004] ] [13:50:57]: Error connecting to 10.60.76.105:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:50:58 | E [d.T.TCPConnection[9004] ] [13:50:58]: Error connecting to 10.60.76.66:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:51:06 | E [d.T.TCPConnection[9004] ] [13:51:06]: Error connecting to 10.60.76.174:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:51:06 | E [d.T.TCPConnection[9004] ] [13:51:06]: Error connecting to 10.60.77.87:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:51:08 | E [d.T.TCPConnection[9004] ] [13:51:08]: Error connecting to 10.59.7.240:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:51:43 | I [O.DAServer[Matrikon OPC Omron]] [13:51:43]: Server 'Matrikon OPC Omron' state set to [CONNECTING]
INFO | jvm 1 | 2021/05/13 08:51:43 | I [O.DAServer[Matrikon OPC Omron]] [13:51:43]: Attempting to connect COM server 'Matrikon OPC Omron'
INFO | jvm 1 | 2021/05/13 08:51:43 | E [O.DAServer[Matrikon OPC Omron]] [13:51:43]: Error connecting OPC-COM server.
INFO | jvm 1 | 2021/05/13 08:51:43 | com.jniwrapper.win32.com.ComException: COM object method returns error code: 0x800700A4; No more threads can be created in the system.
INFO | jvm 1 | 2021/05/13 08:51:43 | at com.jniwrapper.win32.com.ComException.checkResult(SourceFile:172)
INFO | jvm 1 | 2021/05/13 08:51:43 | at com.jniwrapper.win32.com.ComFunctions.coCreateInstanceEx(SourceFile:230)
INFO | jvm 1 | 2021/05/13 08:51:43 | at com.inductiveautomation.opccom.COMServerImpl$ConnectServerJob.internalRun(COMServerImpl.java:662)
INFO | jvm 1 | 2021/05/13 08:51:43 | at com.inductiveautomation.opccom.wrapper.OleJob.run(OleJob.java:48)
INFO | jvm 1 | 2021/05/13 08:51:43 | at com.jniwrapper.win32.MessageLoopThread$ThreadSynchronizedAction.run(MessageLoopThread.java:620)
INFO | jvm 1 | 2021/05/13 08:51:43 | at com.jniwrapper.win32.MessageLoopThread$LoopThread.run(MessageLoopThread.java:562)
INFO | jvm 1 | 2021/05/13 08:51:43 | I [O.DAServer[Matrikon OPC Omron]] [13:51:43]: Disconnecting server 'Matrikon OPC Omron', healthy: false
INFO | jvm 1 | 2021/05/13 08:51:43 | I [O.DAServer[Matrikon OPC Omron]] [13:51:43]: Server 'Matrikon OPC Omron' state set to [CLOSED]
INFO | jvm 1 | 2021/05/13 08:51:43 | I [c.i.o.w.s.COMSubscription ] [13:51:43]: Shutting down subscription 'Scanclass 'Default[default]''. Is healthy shutdown: false
INFO | jvm 1 | 2021/05/13 08:51:43 | I [c.i.o.w.s.COMSubscription ] [13:51:43]: Shutting down subscription 'Scanclass 'Fast Scan[default]''. Is healthy shutdown: false
INFO | jvm 1 | 2021/05/13 08:51:43 | I [O.DAServer[Matrikon OPC Omron]] [13:51:43]: Server 'Matrikon OPC Omron' state set to [FAULTED]
INFO | jvm 1 | 2021/05/13 08:51:59 | E [d.T.TCPConnection[9004] ] [13:51:59]: Error connecting to 10.60.78.171:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:52:03 | E [d.T.TCPConnection[9004] ] [13:52:03]: Error connecting to 10.60.76.105:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:52:04 | E [d.T.TCPConnection[9004] ] [13:52:04]: Error connecting to 10.60.76.66:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:52:06 | E [d.T.TCPConnection[9004] ] [13:52:06]: Error connecting to 10.60.78.172:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:52:15 | E [d.T.TCPConnection[9004] ] [13:52:15]: Error connecting to 10.59.7.240:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:52:18 | E [d.T.TCPConnection[9004] ] [13:52:18]: Error connecting to 10.60.76.174:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:52:18 | E [d.T.TCPConnection[9004] ] [13:52:18]: Error connecting to 10.60.77.87:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:52:43 | I [O.DAServer[Matrikon OPC Omron]] [13:52:43]: Server 'Matrikon OPC Omron' state set to [CONNECTING]
INFO | jvm 1 | 2021/05/13 08:52:43 | I [O.DAServer[Matrikon OPC Omron]] [13:52:43]: Attempting to connect COM server 'Matrikon OPC Omron'
INFO | jvm 1 | 2021/05/13 08:52:43 | E [O.DAServer[Matrikon OPC Omron]] [13:52:43]: Error connecting OPC-COM server.
INFO | jvm 1 | 2021/05/13 08:52:43 | com.jniwrapper.win32.com.ComException: COM object method returns error code: 0x800700A4; No more threads can be created in the system.
INFO | jvm 1 | 2021/05/13 08:52:43 | at com.jniwrapper.win32.com.ComException.checkResult(SourceFile:172)
INFO | jvm 1 | 2021/05/13 08:52:43 | at com.jniwrapper.win32.com.ComFunctions.coCreateInstanceEx(SourceFile:230)
INFO | jvm 1 | 2021/05/13 08:52:43 | at com.inductiveautomation.opccom.COMServerImpl$ConnectServerJob.internalRun(COMServerImpl.java:662)
INFO | jvm 1 | 2021/05/13 08:52:43 | at com.inductiveautomation.opccom.wrapper.OleJob.run(OleJob.java:48)
INFO | jvm 1 | 2021/05/13 08:52:43 | at com.jniwrapper.win32.MessageLoopThread$ThreadSynchronizedAction.run(MessageLoopThread.java:620)
INFO | jvm 1 | 2021/05/13 08:52:43 | at com.jniwrapper.win32.MessageLoopThread$LoopThread.run(MessageLoopThread.java:562)
INFO | jvm 1 | 2021/05/13 08:52:43 | I [O.DAServer[Matrikon OPC Omron]] [13:52:43]: Disconnecting server 'Matrikon OPC Omron', healthy: false
INFO | jvm 1 | 2021/05/13 08:52:43 | I [O.DAServer[Matrikon OPC Omron]] [13:52:43]: Server 'Matrikon OPC Omron' state set to [CLOSED]
INFO | jvm 1 | 2021/05/13 08:52:43 | I [c.i.o.w.s.COMSubscription ] [13:52:43]: Shutting down subscription 'Scanclass 'Default[default]''. Is healthy shutdown: false
INFO | jvm 1 | 2021/05/13 08:52:43 | I [c.i.o.w.s.COMSubscription ] [13:52:43]: Shutting down subscription 'Scanclass 'Fast Scan[default]''. Is healthy shutdown: false
INFO | jvm 1 | 2021/05/13 08:52:43 | I [O.DAServer[Matrikon OPC Omron]] [13:52:43]: Server 'Matrikon OPC Omron' state set to [FAULTED]
INFO | jvm 1 | 2021/05/13 08:53:05 | E [d.T.TCPConnection[9004] ] [13:53:05]: Error connecting to 10.60.78.171:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:53:16 | E [d.T.TCPConnection[9004] ] [13:53:15]: Error connecting to 10.60.76.105:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:53:16 | E [d.T.TCPConnection[9004] ] [13:53:16]: Error connecting to 10.60.76.66:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:53:18 | E [d.T.TCPConnection[9004] ] [13:53:18]: Error connecting to 10.60.78.172:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:53:24 | E [d.T.TCPConnection[9004] ] [13:53:24]: Error connecting to 10.60.76.174:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:53:24 | E [d.T.TCPConnection[9004] ] [13:53:24]: Error connecting to 10.60.77.87:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:53:27 | E [d.T.TCPConnection[9004] ] [13:53:27]: Error connecting to 10.59.7.240:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:53:43 | I [O.DAServer[Matrikon OPC Omron]] [13:53:43]: Server 'Matrikon OPC Omron' state set to [CONNECTING]
INFO | jvm 1 | 2021/05/13 08:53:43 | I [O.DAServer[Matrikon OPC Omron]] [13:53:43]: Attempting to connect COM server 'Matrikon OPC Omron'
INFO | jvm 1 | 2021/05/13 08:53:43 | E [O.DAServer[Matrikon OPC Omron]] [13:53:43]: Error connecting OPC-COM server.
INFO | jvm 1 | 2021/05/13 08:53:43 | com.jniwrapper.win32.com.ComException: COM object method returns error code: 0x800700A4; No more threads can be created in the system.
INFO | jvm 1 | 2021/05/13 08:53:43 | at com.jniwrapper.win32.com.ComException.checkResult(SourceFile:172)
INFO | jvm 1 | 2021/05/13 08:53:43 | at com.jniwrapper.win32.com.ComFunctions.coCreateInstanceEx(SourceFile:230)
INFO | jvm 1 | 2021/05/13 08:53:43 | at com.inductiveautomation.opccom.COMServerImpl$ConnectServerJob.internalRun(COMServerImpl.java:662)
INFO | jvm 1 | 2021/05/13 08:53:43 | at com.inductiveautomation.opccom.wrapper.OleJob.run(OleJob.java:48)
INFO | jvm 1 | 2021/05/13 08:53:43 | at com.jniwrapper.win32.MessageLoopThread$ThreadSynchronizedAction.run(MessageLoopThread.java:620)
INFO | jvm 1 | 2021/05/13 08:53:43 | at com.jniwrapper.win32.MessageLoopThread$LoopThread.run(MessageLoopThread.java:562)
INFO | jvm 1 | 2021/05/13 08:53:43 | I [O.DAServer[Matrikon OPC Omron]] [13:53:43]: Disconnecting server 'Matrikon OPC Omron', healthy: false
INFO | jvm 1 | 2021/05/13 08:53:43 | I [O.DAServer[Matrikon OPC Omron]] [13:53:43]: Server 'Matrikon OPC Omron' state set to [CLOSED]
INFO | jvm 1 | 2021/05/13 08:53:43 | I [c.i.o.w.s.COMSubscription ] [13:53:43]: Shutting down subscription 'Scanclass 'Default[default]''. Is healthy shutdown: false
INFO | jvm 1 | 2021/05/13 08:53:43 | I [c.i.o.w.s.COMSubscription ] [13:53:43]: Shutting down subscription 'Scanclass 'Fast Scan[default]''. Is healthy shutdown: false
INFO | jvm 1 | 2021/05/13 08:53:43 | I [O.DAServer[Matrikon OPC Omron]] [13:53:43]: Server 'Matrikon OPC Omron' state set to [FAULTED]
INFO | jvm 1 | 2021/05/13 08:54:17 | E [d.T.TCPConnection[9004] ] [13:54:17]: Error connecting to 10.60.78.171:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:54:17 | [Catapult] [1620914057793]: Received GetMainContextDetailsRequest
INFO | jvm 1 | 2021/05/13 08:54:17 | [Catapult] [1620914057803]: Returning GetMainContextDetailsResponse (10ms elapsed)
INFO | jvm 1 | 2021/05/13 08:54:24 | E [d.T.TCPConnection[9004] ] [13:54:24]: Error connecting to 10.60.78.172:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:54:28 | E [d.T.TCPConnection[9004] ] [13:54:28]: Error connecting to 10.60.76.105:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:54:28 | E [d.T.TCPConnection[9004] ] [13:54:28]: Error connecting to 10.60.76.66:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:54:30 | [Catapult] [1620914070788]: Received GetMainContextDetailsRequest
INFO | jvm 1 | 2021/05/13 08:54:30 | [Catapult] [1620914070788]: Returning GetMainContextDetailsResponse (0ms elapsed)
INFO | jvm 1 | 2021/05/13 08:54:36 | E [d.T.TCPConnection[9004] ] [13:54:36]: Error connecting to 10.60.77.87:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:54:36 | E [d.T.TCPConnection[9004] ] [13:54:36]: Error connecting to 10.60.76.174:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:54:39 | E [d.T.TCPConnection[9004] ] [13:54:39]: Error connecting to 10.59.7.240:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:54:43 | I [O.DAServer[Matrikon OPC Omron]] [13:54:43]: Server 'Matrikon OPC Omron' state set to [CONNECTING]
INFO | jvm 1 | 2021/05/13 08:54:43 | I [O.DAServer[Matrikon OPC Omron]] [13:54:43]: Attempting to connect COM server 'Matrikon OPC Omron'
INFO | jvm 1 | 2021/05/13 08:54:43 | E [O.DAServer[Matrikon OPC Omron]] [13:54:43]: Error connecting OPC-COM server.
INFO | jvm 1 | 2021/05/13 08:54:43 | com.jniwrapper.win32.com.ComException: COM object method returns error code: 0x800700A4; No more threads can be created in the system.
INFO | jvm 1 | 2021/05/13 08:54:43 | at com.jniwrapper.win32.com.ComException.checkResult(SourceFile:172)
INFO | jvm 1 | 2021/05/13 08:54:43 | at com.jniwrapper.win32.com.ComFunctions.coCreateInstanceEx(SourceFile:230)
INFO | jvm 1 | 2021/05/13 08:54:43 | at com.inductiveautomation.opccom.COMServerImpl$ConnectServerJob.internalRun(COMServerImpl.java:662)
INFO | jvm 1 | 2021/05/13 08:54:43 | at com.inductiveautomation.opccom.wrapper.OleJob.run(OleJob.java:48)
INFO | jvm 1 | 2021/05/13 08:54:43 | at com.jniwrapper.win32.MessageLoopThread$ThreadSynchronizedAction.run(MessageLoopThread.java:620)
INFO | jvm 1 | 2021/05/13 08:54:43 | at com.jniwrapper.win32.MessageLoopThread$LoopThread.run(MessageLoopThread.java:562)
INFO | jvm 1 | 2021/05/13 08:54:43 | I [O.DAServer[Matrikon OPC Omron]] [13:54:43]: Disconnecting server 'Matrikon OPC Omron', healthy: false
INFO | jvm 1 | 2021/05/13 08:54:43 | I [O.DAServer[Matrikon OPC Omron]] [13:54:43]: Server 'Matrikon OPC Omron' state set to [CLOSED]
INFO | jvm 1 | 2021/05/13 08:54:43 | I [c.i.o.w.s.COMSubscription ] [13:54:43]: Shutting down subscription 'Scanclass 'Default[default]''. Is healthy shutdown: false
INFO | jvm 1 | 2021/05/13 08:54:43 | I [c.i.o.w.s.COMSubscription ] [13:54:43]: Shutting down subscription 'Scanclass 'Fast Scan[default]''. Is healthy shutdown: false
INFO | jvm 1 | 2021/05/13 08:54:43 | I [O.DAServer[Matrikon OPC Omron]] [13:54:43]: Server 'Matrikon OPC Omron' state set to [FAULTED]
INFO | jvm 1 | 2021/05/13 08:55:23 | E [d.T.TCPConnection[9004] ] [13:55:23]: Error connecting to 10.60.78.171:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:55:30 | [Catapult] [1620914130787]: Received GetMainContextDetailsRequest
INFO | jvm 1 | 2021/05/13 08:55:30 | [Catapult] [1620914130787]: Returning GetMainContextDetailsResponse (0ms elapsed)
INFO | jvm 1 | 2021/05/13 08:55:34 | E [d.T.TCPConnection[9004] ] [13:55:34]: Error connecting to 10.60.76.105:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:55:34 | E [d.T.TCPConnection[9004] ] [13:55:34]: Error connecting to 10.60.76.66:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:55:36 | E [d.T.TCPConnection[9004] ] [13:55:36]: Error connecting to 10.60.78.172:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:55:43 | I [O.DAServer[Matrikon OPC Omron]] [13:55:43]: Server 'Matrikon OPC Omron' state set to [CONNECTING]
INFO | jvm 1 | 2021/05/13 08:55:43 | I [O.DAServer[Matrikon OPC Omron]] [13:55:43]: Attempting to connect COM server 'Matrikon OPC Omron'
INFO | jvm 1 | 2021/05/13 08:55:43 | E [O.DAServer[Matrikon OPC Omron]] [13:55:43]: Error connecting OPC-COM server.
INFO | jvm 1 | 2021/05/13 08:55:43 | com.jniwrapper.win32.com.ComException: COM object method returns error code: 0x800700A4; No more threads can be created in the system.
INFO | jvm 1 | 2021/05/13 08:55:43 | at com.jniwrapper.win32.com.ComException.checkResult(SourceFile:172)
INFO | jvm 1 | 2021/05/13 08:55:43 | at com.jniwrapper.win32.com.ComFunctions.coCreateInstanceEx(SourceFile:230)
INFO | jvm 1 | 2021/05/13 08:55:43 | at com.inductiveautomation.opccom.COMServerImpl$ConnectServerJob.internalRun(COMServerImpl.java:662)
INFO | jvm 1 | 2021/05/13 08:55:43 | at com.inductiveautomation.opccom.wrapper.OleJob.run(OleJob.java:48)
INFO | jvm 1 | 2021/05/13 08:55:43 | at com.jniwrapper.win32.MessageLoopThread$ThreadSynchronizedAction.run(MessageLoopThread.java:620)
INFO | jvm 1 | 2021/05/13 08:55:43 | at com.jniwrapper.win32.MessageLoopThread$LoopThread.run(MessageLoopThread.java:562)
INFO | jvm 1 | 2021/05/13 08:55:43 | I [O.DAServer[Matrikon OPC Omron]] [13:55:43]: Disconnecting server 'Matrikon OPC Omron', healthy: false
INFO | jvm 1 | 2021/05/13 08:55:43 | I [O.DAServer[Matrikon OPC Omron]] [13:55:43]: Server 'Matrikon OPC Omron' state set to [CLOSED]
INFO | jvm 1 | 2021/05/13 08:55:43 | I [c.i.o.w.s.COMSubscription ] [13:55:43]: Shutting down subscription 'Scanclass 'Default[default]''. Is healthy shutdown: false
INFO | jvm 1 | 2021/05/13 08:55:43 | I [c.i.o.w.s.COMSubscription ] [13:55:43]: Shutting down subscription 'Scanclass 'Fast Scan[default]''. Is healthy shutdown: false
INFO | jvm 1 | 2021/05/13 08:55:43 | I [O.DAServer[Matrikon OPC Omron]] [13:55:43]: Server 'Matrikon OPC Omron' state set to [FAULTED]
INFO | jvm 1 | 2021/05/13 08:55:45 | E [d.T.TCPConnection[9004] ] [13:55:45]: Error connecting to 10.59.7.240:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:55:48 | E [d.T.TCPConnection[9004] ] [13:55:48]: Error connecting to 10.60.77.87:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:55:48 | E [d.T.TCPConnection[9004] ] [13:55:48]: Error connecting to 10.60.76.174:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:56:33 | [Catapult] [1620914193788]: Received GetMainContextDetailsRequest
INFO | jvm 1 | 2021/05/13 08:56:33 | [Catapult] [1620914193788]: Returning GetMainContextDetailsResponse (0ms elapsed)
INFO | jvm 1 | 2021/05/13 08:56:35 | E [d.T.TCPConnection[9004] ] [13:56:35]: Error connecting to 10.60.78.171:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:56:43 | I [O.DAServer[Matrikon OPC Omron]] [13:56:43]: Server 'Matrikon OPC Omron' state set to [CONNECTING]
INFO | jvm 1 | 2021/05/13 08:56:43 | I [O.DAServer[Matrikon OPC Omron]] [13:56:43]: Attempting to connect COM server 'Matrikon OPC Omron'
INFO | jvm 1 | 2021/05/13 08:56:43 | E [O.DAServer[Matrikon OPC Omron]] [13:56:43]: Error connecting OPC-COM server.
INFO | jvm 1 | 2021/05/13 08:56:43 | com.jniwrapper.win32.com.ComException: COM object method returns error code: 0x800700A4; No more threads can be created in the system.
INFO | jvm 1 | 2021/05/13 08:56:43 | at com.jniwrapper.win32.com.ComException.checkResult(SourceFile:172)
INFO | jvm 1 | 2021/05/13 08:56:43 | at com.jniwrapper.win32.com.ComFunctions.coCreateInstanceEx(SourceFile:230)
INFO | jvm 1 | 2021/05/13 08:56:43 | at com.inductiveautomation.opccom.COMServerImpl$ConnectServerJob.internalRun(COMServerImpl.java:662)
INFO | jvm 1 | 2021/05/13 08:56:43 | at com.inductiveautomation.opccom.wrapper.OleJob.run(OleJob.java:48)
INFO | jvm 1 | 2021/05/13 08:56:43 | at com.jniwrapper.win32.MessageLoopThread$ThreadSynchronizedAction.run(MessageLoopThread.java:620)
INFO | jvm 1 | 2021/05/13 08:56:43 | at com.jniwrapper.win32.MessageLoopThread$LoopThread.run(MessageLoopThread.java:562)
INFO | jvm 1 | 2021/05/13 08:56:43 | I [O.DAServer[Matrikon OPC Omron]] [13:56:43]: Disconnecting server 'Matrikon OPC Omron', healthy: false
INFO | jvm 1 | 2021/05/13 08:56:43 | I [O.DAServer[Matrikon OPC Omron]] [13:56:43]: Server 'Matrikon OPC Omron' state set to [CLOSED]
INFO | jvm 1 | 2021/05/13 08:56:43 | I [c.i.o.w.s.COMSubscription ] [13:56:43]: Shutting down subscription 'Scanclass 'Default[default]''. Is healthy shutdown: false
INFO | jvm 1 | 2021/05/13 08:56:43 | I [c.i.o.w.s.COMSubscription ] [13:56:43]: Shutting down subscription 'Scanclass 'Fast Scan[default]''. Is healthy shutdown: false
INFO | jvm 1 | 2021/05/13 08:56:43 | I [O.DAServer[Matrikon OPC Omron]] [13:56:43]: Server 'Matrikon OPC Omron' state set to [FAULTED]
INFO | jvm 1 | 2021/05/13 08:56:46 | E [d.T.TCPConnection[9004] ] [13:56:46]: Error connecting to 10.60.76.105:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:56:46 | E [d.T.TCPConnection[9004] ] [13:56:46]: Error connecting to 10.60.76.66:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:56:48 | E [d.T.TCPConnection[9004] ] [13:56:48]: Error connecting to 10.60.78.172:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:56:54 | E [d.T.TCPConnection[9004] ] [13:56:54]: Error connecting to 10.60.77.87:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:56:55 | E [d.T.TCPConnection[9004] ] [13:56:54]: Error connecting to 10.60.76.174:9004. Connection refused: connect
INFO | jvm 1 | 2021/05/13 08:56:58 | E [d.T.TCPConnection[9004] ] [13:56:58]: Error connecting to 10.59.7.240:9004. Connection refused: connect
