I’m sure I’m missing something very obvious, but I’m having a problem setting the .text property of a Text Field after a double click. I would like the current date / time to be entered into a Text field when the user double clicks in the field.
Here is my code which doesn’t work.
Under the MouseClicked event:
if event.clickCount == 2:
today = system.date.now()
timestamp= system.date.format(today,event.source.Format)
event.source.text = timestamp
the event.source.text will not update. I noticed if I hit the Enter key while I’m double clicking then the change is made. I guess I need to be able to programmatically send the enter key, but I’m haven’t figured out how to do that. Any help would be greatly appreciated.
Thanks!
