Hello,
I got problem to connect my prosys client to the server … Should I change some permission on the ignition server for this?
Thanks,
~/projects/prosys/Prosys-OPC-UA-Java-SDK-Client-Server-Evaluation-1.4.8-8731/samples$ ./SampleConsoleClient.sh
No server URI defined. (Run with /? to see command line usage)
Would you like to use the default server URI
'opc.tcp://localhost:52520/OPCUA/SampleConsoleServer’?
(Y=Yes, N=No, or just enter a different URI manually)
opc.tcp://10.0.2.15:4096/iaopcua/None
Select the security mode to use.
(n=None,s=Sign,e=SignAndEncrypt)
n
Connecting to opc.tcp://10.0.2.15:4096/iaopcua/none
Prosys OPC UA Java SDK v1.4.8-8731
© Prosys PMS Ltd. http://www.prosysopc.com
Running in EVALUATION mode
Connections will close after 119 minutes
03/18/2014 17:29:00.954 INFO  Reading application certificate from /home/lvboque/projects/prosys/Prosys-OPC-UA-Java-SDK-Client-Server-Evaluation-1.4.8-8731/samples/PKI/CA/private/SampleConsoleClient.der
03/18/2014 17:29:01.064 INFO  Reading private key from keystore /home/lvboque/projects/prosys/Prosys-OPC-UA-Java-SDK-Client-Server-Evaluation-1.4.8-8731/samples/PKI/CA/private/SampleConsoleClient.pem
Using SecurityMode [opcfoundation.org/UA/SecurityPolicy#None,None]
03/18/2014 17:29:02.753 INFO  Using an alternate endpoint URL 'opc.tcp://10.0.2.15:4096/iaopcua/none’
03/18/2014 17:29:02.772 INFO  Failed to CloseSession: ServiceFault: Bad_SessionNotActivated (0x80270000) “The session cannot be used because ActivateSession has not been called.”
Diagnostic Info:
com.prosysopc.ua.SessionActivationException: Failed to initialize User Identity Token: Bad_IdentityTokenRejected (code=0x80210000, description=“Anonymous UserTokenType is not supported”) ServiceResult=Bad_IdentityTokenRejected (0x80210000) “The user identity token is valid but the server has rejected it.”
Caused by: org.opcfoundation.ua.common.ServiceResultException: Bad_IdentityTokenRejected (code=0x80210000, description=“Anonymous UserTokenType is not supported”)
The server supports the following user tokens:
UserName
*** NOT connected to: opc.tcp://10.0.2.15:4096/iaopcua/none
