Ignition v8.0.0 and java 1.8.0_151 on windows10 64 bit
When I try to launch The Designer Launcher,it create an OpenJDK process but no visible window.
I encountered the same problem on windows7.Hope someone can help me to fix it,thanks for that.
Ignition v8 doesn’t use your installed Java, it bundles its own. Make sure you aren’t interfering with that. (It won’t run on java 8, anyways.)
