Problem opening window
After upgrading from 7.9 to 8.1.5 I can’t open a window
com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Unexpected parsing error during binary deserialization.
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserializeBinary(XMLDeserializer.java:367)
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserialize(XMLDeserializer.java:268)
	at com.inductiveautomation.factorypmi.application.model.WindowCache._deserializeWindow(WindowCache.java:381)
	at com.inductiveautomation.factorypmi.application.model.WindowCache._loadWindow(WindowCache.java:324)
	at com.inductiveautomation.factorypmi.application.model.WindowCache.openWindow(WindowCache.java:298)
	at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace$DesigntimeWindowOpener.openWindow(WindowWorkspace.java:3718)
	at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.openWindow(WindowWorkspace.java:1482)
	at com.inductiveautomation.factorypmi.designer.model.navtree.WindowNode.open(WindowNode.java:252)
	at com.inductiveautomation.ignition.designer.navtree.model.AbstractResourceNavTreeNode.onDoubleClick(AbstractResourceNavTreeNode.java:339)
	at com.inductiveautomation.ignition.designer.navtree.NavTreePanel$MouseListener.lambda$mousePressed$0(NavTreePanel.java:684)
Caused by: org.apache.commons.io.IOExceptionWithCause: java.lang.ClassNotFoundException: com.byesapps.busylabel.client.BusylabelComponent
	at com.inductiveautomation.ignition.common.xmlserialization.encoding.Decoders$ClassDecoder.getClassForName(Decoders.java:386)
	at com.inductiveautomation.ignition.common.xmlserialization.encoding.Decoders$ClassDecoder.binaryToObject(Decoders.java:400)
	at com.inductiveautomation.ignition.common.xmlserialization.encoding.Decoders$ClassDecoder.binaryToObject(Decoders.java:359)
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readAttributes(BinaryParser.java:179)
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:148)
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:157)
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.parse(BinaryParser.java:51)
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserializeBinary(XMLDeserializer.java:358)
	... 22 more
Caused by: java.lang.ClassNotFoundException: com.byesapps.busylabel.client.BusylabelComponent
	at java.base/java.net.URLClassLoader.findClass(Unknown Source)
	at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
	at java.base/java.lang.Class.forName0(Native Method)
	at java.base/java.lang.Class.forName(Unknown Source)
	at com.inductiveautomation.ignition.common.xmlserialization.ClassNameResolver.classForNameImpl(ClassNameResolver.java:196)
	at com.inductiveautomation.ignition.common.xmlserialization.ClassNameResolver.classForName(ClassNameResolver.java:169)
	at com.inductiveautomation.ignition.common.xmlserialization.encoding.Decoders$ClassDecoder.getClassForName(Decoders.java:376)
	... 37 more
Ignition v8.1.5 (b2021042810)
Java: Azul Systems, Inc. 11.0.10
Do you have all the same add-on modules in v8.1 ? And they all loaded? Any hints about that would be in the client debug console.
Also, screen shots are generally unhelpful when it comes to error stack traces and code, try as I might I just cant scroll down to see all of the stack. :wink:
Copy the entire error and paste it into a preformatted text block.
Hint: click the </> button or use Ctrl + Shift + C to insert a preformatted text block.
All modules work fine, the window won’t open in the designer and client
With the full error it looks like it is having issue with a BusylabelComponent
Did the 7.9 server have a third party module installed? Have you installed the correct version of that module?
The root cause is this:
Which seems to be a reference to a 3rd party component that is not found for some reason. I’m guessing you do not have the new 8.x version of this module; it certainly wouldn’t be part of our installer.
Its true, is there any way to remove it?
Open your projects in 7.9, and remove the busy label, then re-import.
If you still need something to replace it:
