I installed Ignition (version 7.9.8-windows-x64) since I must perform a system migration. When restoring through the web page using a system backup the web server and the gateway are stopped and also the ports are listed as unknown. You have seen this in the launch gateway control utility. Any help?
Have a look at the wrapper log for any errors. It could be that not enough memory is allocated within the ignition.conf file.
Please see below wrapper log
INFO | jvm 1 | 2020/05/14 10:17:04 | I [c.i.i.g.u.BackupRestoreDelegate] [14:17:04]: Starting restore procedure, writing upload to disk…
INFO | jvm 1 | 2020/05/14 10:17:05 | I [c.i.i.g.u.BackupRestoreDelegate] [14:17:05]: Restarting gateway in order to load restore.
INFO | jvm 1 | 2020/05/14 10:17:05 | I [IgnitionGateway ] [14:17:05]: Restarting JVM
INFO | jvm 1 | 2020/05/14 10:17:06 | I [IgnitionGateway ] [14:17:06]: Ignition[state=RUNNING] ContextState = STOPPING
INFO | jvm 1 | 2020/05/14 10:17:06 | I [IgnitionGateway ] [14:17:06]: Ignition Gateway shutting down…
INFO | jvm 1 | 2020/05/14 10:17:06 | I [g.ModuleManager ] [14:17:06]: ModuleManager shutting down…
INFO | jvm 1 | 2020/05/14 10:17:06 | I [g.ModuleManager ] [14:17:06]: Shutting down module ‘com.inductiveautomation.reporting’ v5.0.12 (b2020042115)… module-name=Reporting
INFO | jvm 1 | 2020/05/14 10:17:06 | W [c.i.r.g.ReportingGwPerspectiveInit] [14:17:06]: Perspective module was not found or was not running, could not unregister reporting components. module-name=Reporting
INFO | jvm 1 | 2020/05/14 10:17:06 | I [g.ModuleManager ] [14:17:06]: Shutdown of module “com.inductiveautomation.reporting” completed in 1 ms module-name=Reporting
INFO | jvm 1 | 2020/05/14 10:17:06 | I [g.ModuleManager ] [14:17:06]: Shutting down module ‘com.inductiveautomation.opcua.drivers.ablegacy’ v5.0.12 (b2020042115)… module-name=Allen-Bradley Driver
INFO | jvm 1 | 2020/05/14 10:17:06 | I [g.ModuleManager ] [14:17:06]: Shutdown of module “com.inductiveautomation.opcua.drivers.ablegacy” completed in 2 ms module-name=Allen-Bradley Driver
INFO | jvm 1 | 2020/05/14 10:17:06 | I [g.ModuleManager ] [14:17:06]: Shutting down module ‘com.inductiveautomation.opcua.drivers.modbus’ v6.0.12 (b2020042115)… module-name=Modbus Driver
INFO | jvm 1 | 2020/05/14 10:17:06 | I [g.ModuleManager ] [14:17:06]: Shutdown of module “com.inductiveautomation.opcua.drivers.modbus” completed in 0 ms module-name=Modbus Driver
INFO | jvm 1 | 2020/05/14 10:17:06 | I [g.ModuleManager ] [14:17:06]: Shutting down module ‘com.inductiveautomation.opcua.drivers.siemens’ v5.0.12 (b2020042115)… module-name=Siemens Drivers
INFO | jvm 1 | 2020/05/14 10:17:06 | I [g.ModuleManager ] [14:17:06]: Shutdown of module “com.inductiveautomation.opcua.drivers.siemens” completed in 1 ms module-name=Siemens Drivers
INFO | jvm 1 | 2020/05/14 10:17:06 | I [g.ModuleManager ] [14:17:06]: Shutting down module ‘com.inductiveautomation.opcua.drivers.logix’ v4.0.12 (b2020042115)… module-name=Logix Driver
INFO | jvm 1 | 2020/05/14 10:17:06 | I [g.ModuleManager ] [14:17:06]: Shutdown of module “com.inductiveautomation.opcua.drivers.logix” completed in 3 ms module-name=Logix Driver
INFO | jvm 1 | 2020/05/14 10:17:06 | I [g.ModuleManager ] [14:17:06]: Shutting down module ‘com.inductiveautomation.opcua.drivers.dnp3’ v3.0.12 (b2020042115)… module-name=DNP3 Driver
INFO | jvm 1 | 2020/05/14 10:17:06 | I [g.ModuleManager ] [14:17:06]: Shutdown of module “com.inductiveautomation.opcua.drivers.dnp3” completed in 0 ms module-name=DNP3 Driver
INFO | jvm 1 | 2020/05/14 10:17:06 | I [g.ModuleManager ] [14:17:06]: Shutting down module ‘com.inductiveautomation.opcua.drivers.omron’ v3.0.12 (b2020042115)… module-name=Omron Driver
INFO | jvm 1 | 2020/05/14 10:17:06 | I [g.ModuleManager ] [14:17:06]: Shutdown of module “com.inductiveautomation.opcua.drivers.omron” completed in 1 ms module-name=Omron Driver
INFO | jvm 1 | 2020/05/14 10:17:06 | I [g.ModuleManager ] [14:17:06]: Shutting down module ‘com.inductiveautomation.opcua.drivers.tcpudp’ v5.0.12 (b2020042115)… module-name=UDP and TCP Drivers
INFO | jvm 1 | 2020/05/14 10:17:06 | I [g.ModuleManager ] [14:17:06]: Shutdown of module “com.inductiveautomation.opcua.drivers.tcpudp” completed in 1 ms module-name=UDP and TCP Drivers
INFO | jvm 1 | 2020/05/14 10:17:06 | I [g.ModuleManager ] [14:17:06]: Shutting down module ‘com.inductiveautomation.sms-notification’ v5.0.12 (b2020042115)… module-name=SMS Notification
INFO | jvm 1 | 2020/05/14 10:17:06 | I [g.ModuleManager ] [14:17:06]: Shutdown of module “com.inductiveautomation.sms-notification” completed in 4 ms module-name=SMS Notification
INFO | jvm 1 | 2020/05/14 10:17:06 | I [g.ModuleManager ] [14:17:06]: Shutting down module ‘com.inductiveautomation.perspective’ v1.0.12 (b2020042115)… module-name=Perspective
INFO | jvm 1 | 2020/05/14 10:17:06 | I [g.ModuleManager ] [14:17:06]: Shutdown of module “com.inductiveautomation.perspective” completed in 4 ms module-name=Perspective
INFO | jvm 1 | 2020/05/14 10:17:06 | I [g.ModuleManager ] [14:17:06]: Shutting down module ‘com.inductiveautomation.opccom’ v5.0.12 (b2020042115)… module-name=OpcCom
INFO | jvm 1 | 2020/05/14 10:17:06 | I [c.i.o.ModuleHook ] [14:17:06]: Message loop stopped. module-name=OpcCom
INFO | jvm 1 | 2020/05/14 10:17:06 | I [c.i.o.ModuleHook ] [14:17:06]: Cleaning up native resource collector. module-name=OpcCom
INFO | jvm 1 | 2020/05/14 10:17:06 | I [c.i.o.ModuleHook ] [14:17:06]: Shutdown native resource collector. module-name=OpcCom
INFO | jvm 1 | 2020/05/14 10:17:06 | I [c.i.o.ModuleHook ] [14:17:06]: Native thread killed. module-name=OpcCom
INFO | jvm 1 | 2020/05/14 10:17:06 | I [c.i.o.ModuleHook ] [14:17:06]: Native resource collector has stopped. module-name=OpcCom
INFO | jvm 1 | 2020/05/14 10:17:06 | I [c.i.o.ModuleHook ] [14:17:06]: COM-OPC Module shutdown. module-name=OpcCom
INFO | jvm 1 | 2020/05/14 10:17:06 | I [g.ModuleManager ] [14:17:06]: Shutdown of module “com.inductiveautomation.opccom” completed in 25 ms module-name=OpcCom
INFO | jvm 1 | 2020/05/14 10:17:06 | I [g.ModuleManager ] [14:17:06]: Shutting down module ‘com.inductiveautomation.vision’ v10.0.12 (b2020042115)… module-name=Vision
INFO | jvm 1 | 2020/05/14 10:17:06 | I [g.ModuleManager ] [14:17:06]: Shutdown of module “com.inductiveautomation.vision” completed in 2 ms module-name=Vision
INFO | jvm 1 | 2020/05/14 10:17:06 | I [g.ModuleManager ] [14:17:06]: Shutting down module ‘com.inductiveautomation.taghistorian’ v3.0.12 (b2020042115)… module-name=Tag Historian
INFO | jvm 1 | 2020/05/14 10:17:06 | I [h.ModuleHook ] [14:17:06]: Tag Historian module stopped. module-name=Tag Historian
INFO | jvm 1 | 2020/05/14 10:17:06 | I [g.ModuleManager ] [14:17:06]: Shutdown of module “com.inductiveautomation.taghistorian” completed in 7 ms module-name=Tag Historian
INFO | jvm 1 | 2020/05/14 10:17:06 | I [g.ModuleManager ] [14:17:06]: Shutting down module ‘com.inductiveautomation.sqlbridge’ v9.0.12 (b2020042115)… module-name=SQL Bridge
INFO | jvm 1 | 2020/05/14 10:17:06 | I [g.ModuleManager ] [14:17:06]: Shutdown of module “com.inductiveautomation.sqlbridge” completed in 4 ms module-name=SQL Bridge
INFO | jvm 1 | 2020/05/14 10:17:06 | I [g.ModuleManager ] [14:17:06]: Shutting down module ‘com.inductiveautomation.eam’ v3.0.12 (b2020042115)… module-name=Enterprise Administration
INFO | jvm 1 | 2020/05/14 10:17:06 | I [g.ModuleManager ] [14:17:06]: Shutdown of module “com.inductiveautomation.eam” completed in 0 ms module-name=Enterprise Administration
INFO | jvm 1 | 2020/05/14 10:17:06 | I [g.ModuleManager ] [14:17:06]: Shutting down module ‘com.inductiveautomation.opcua’ v8.0.12 (b2020042115)… module-name=OPC-UA
INFO | jvm 1 | 2020/05/14 10:17:08 | I [g.ModuleManager ] [14:17:08]: Shutdown of module “com.inductiveautomation.opcua” completed in 2 seconds module-name=OPC-UA
INFO | jvm 1 | 2020/05/14 10:17:08 | I [g.ModuleManager ] [14:17:08]: Shutting down module ‘com.inductiveautomation.sfc’ v4.0.12 (b2020042115)… module-name=SFC
INFO | jvm 1 | 2020/05/14 10:17:08 | I [g.ModuleManager ] [14:17:08]: Shutdown of module “com.inductiveautomation.sfc” completed in 3 ms module-name=SFC
INFO | jvm 1 | 2020/05/14 10:17:08 | I [g.ModuleManager ] [14:17:08]: Shutting down module ‘com.inductiveautomation.alarm-notification’ v5.0.12 (b2020042115)… module-name=Alarm Notification
INFO | jvm 1 | 2020/05/14 10:17:08 | I [g.ModuleManager ] [14:17:08]: Shutdown of module “com.inductiveautomation.alarm-notification” completed in 4 ms module-name=Alarm Notification
INFO | jvm 1 | 2020/05/14 10:17:08 | I [g.ModuleManager ] [14:17:08]: ModuleManager shut down in 2474ms
INFO | jvm 1 | 2020/05/14 10:17:08 | W [C.BasicExecutionEngine ] [14:17:08]: Tried to unregister non existent unit [gwnetwork-tagproviderservice sub_validation].
INFO | jvm 1 | 2020/05/14 10:17:08 | I [c.i.i.g.g.WSChannelManager ] [14:17:08]: Shutting down GAN channel manager.
INFO | jvm 1 | 2020/05/14 10:17:08 | I [t.m.provider ] [14:17:08]: Tag provider stopped.
INFO | jvm 1 | 2020/05/14 10:17:08 | E [t.m.provider ] [14:17:08]: Tag provider stopped multiple times. provider=System
INFO | jvm 1 | 2020/05/14 10:17:08 | I [t.h.query ] [14:17:08]: Shutting down…
INFO | jvm 1 | 2020/05/14 10:17:08 | I [G.OpcConnectionManager ] [14:17:08]: OPCManager is shutting down…
INFO | jvm 1 | 2020/05/14 10:17:08 | I [G.OpcConnectionManager ] [14:17:08]: Shutting down connection ‘Ignition OPC UA Server’…
INFO | jvm 1 | 2020/05/14 10:17:08 | I [G.OpcConnectionManager ] [14:17:08]: Shutdown of connection ‘Ignition OPC UA Server’ complete
INFO | jvm 1 | 2020/05/14 10:17:08 | I [G.OpcConnectionManager ] [14:17:08]: OPCManager shut down in 1ms
INFO | jvm 1 | 2020/05/14 10:17:08 | I [SessionManager ] [14:17:08]: Shutting down…
INFO | jvm 1 | 2020/05/14 10:17:08 | I [A.N.NotificationManager ] [14:17:08]: Shutting down…
INFO | jvm 1 | 2020/05/14 10:17:08 | I [A.S.StorageManager ] [14:17:08]: Shutting down…
INFO | jvm 1 | 2020/05/14 10:17:08 | I [AuditManager ] [14:17:08]: AuditManager shutting down…
INFO | jvm 1 | 2020/05/14 10:17:08 | I [i.UserSourceManager ] [14:17:08]: Shutting down…
INFO | jvm 1 | 2020/05/14 10:17:08 | I [g.Database ] [14:17:08]: Datasource manager shutting down…
INFO | jvm 1 | 2020/05/14 10:17:08 | I [C.BasicExecutionEngine ] [14:17:08]: Execution engine ‘Database Connection Validator’ shut down in 0ms
INFO | jvm 1 | 2020/05/14 10:17:08 | I [g.InternalDatabaseManager ] [14:17:08]: DBManager shutting down (immediate)…
INFO | jvm 1 | 2020/05/14 10:17:08 | I [P.InternalDatabase ] [14:17:08]: internal database “config.idb” shutting down…
INFO | jvm 1 | 2020/05/14 10:17:08 | I [P.InternalDatabase ] [14:17:08]: internal database “config.idb” shut down in 1ms
INFO | jvm 1 | 2020/05/14 10:17:08 | I [g.InternalDatabaseManager ] [14:17:08]: DBManager shut down in 5ms
INFO | jvm 1 | 2020/05/14 10:17:08 | I [IgnitionGateway ] [14:17:08]: Platform module services uninitialized.
INFO | jvm 1 | 2020/05/14 10:17:08 | I [c.i.i.g.m.MulticastScheduler ] [14:17:08]: MulticastScheduler shutting down.
INFO | jvm 1 | 2020/05/14 10:17:08 | I [g.ClientFallbackController ] [14:17:08]: Fallback Socket Controller shutting down.
INFO | jvm 1 | 2020/05/14 10:17:08 | I [C.BasicExecutionEngine ] [14:17:08]: Execution engine ‘MetricHistoryManager’ shut down in 0ms
INFO | jvm 1 | 2020/05/14 10:17:08 | I [g.IdpAdapterManager ] [14:17:08]: Shut down in 0 ms
INFO | jvm 1 | 2020/05/14 10:17:08 | I [g.PersistentRecordIdpAdapterMetricsService] [14:17:08]: Shut down in 0 ms
INFO | jvm 1 | 2020/05/14 10:17:08 | I [g.PersistentRecordIdpAdapterConfigService] [14:17:08]: Shut down in 0 ms
INFO | jvm 1 | 2020/05/14 10:17:08 | I [g.SecurityLevelManager ] [14:17:08]: Shut down in 0 ms
INFO | jvm 1 | 2020/05/14 10:17:08 | I [g.PersistentRecordSecurityLevelConfigService] [14:17:08]: Shut down in 0 ms
INFO | jvm 1 | 2020/05/14 10:17:08 | I [IgnitionGateway ] [14:17:08]: Ignition Gateway shut down in 2530ms
INFO | jvm 1 | 2020/05/14 10:17:08 | 10:17:08,550 |-INFO in ch.qos.logback.classic.AsyncAppender[SysoutAsync] - Worker thread will flush remaining events before exiting.
INFO | jvm 1 | 2020/05/14 10:17:08 | 10:17:08,552 |-INFO in ch.qos.logback.classic.AsyncAppender[SysoutAsync] - Queue flush finished successfully within timeout.
INFO | jvm 1 | 2020/05/14 10:17:08 | 10:17:08,552 |-INFO in ch.qos.logback.classic.AsyncAppender[DBAsync] - Worker thread will flush remaining events before exiting.
INFO | jvm 1 | 2020/05/14 10:17:08 | 10:17:08,552 |-INFO in ch.qos.logback.classic.AsyncAppender[DBAsync] - Queue flush finished successfully within timeout.
STATUS | wrapper | 2020/05/14 10:17:11 | on_exit trigger matched. Restarting the JVM. (Exit code: 2)
STATUS | wrapper | 2020/05/14 10:17:15 | Reloading Wrapper configuration…
STATUS | wrapper | 2020/05/14 10:17:15 | Launching a JVM…
INFO | jvm 2 | 2020/05/14 10:17:16 | [0.004s][warning][gc] -Xloggc is deprecated. Will use -Xlog:gc:C:/Program Files/Inductive Automation/Ignition/logs/javagc-20200514101715.log instead.
INFO | jvm 2 | 2020/05/14 10:17:16 | Unrecognized VM option ‘PrintGCTimeStamps’
INFO | jvm 2 | 2020/05/14 10:17:16 | Error: Could not create the Java Virtual Machine.
INFO | jvm 2 | 2020/05/14 10:17:16 | Error: A fatal exception has occurred. Program will exit.
ERROR | wrapper | 2020/05/14 10:17:16 | JVM exited while loading the application.
STATUS | wrapper | 2020/05/14 10:17:20 | Reloading Wrapper configuration…
STATUS | wrapper | 2020/05/14 10:17:20 | Launching a JVM…
INFO | jvm 3 | 2020/05/14 10:17:20 | [0.003s][warning][gc] -Xloggc is deprecated. Will use -Xlog:gc:C:/Program Files/Inductive Automation/Ignition/logs/javagc-20200514101720.log instead.
INFO | jvm 3 | 2020/05/14 10:17:20 | Unrecognized VM option ‘PrintGCTimeStamps’
INFO | jvm 3 | 2020/05/14 10:17:20 | Error: Could not create the Java Virtual Machine.
INFO | jvm 3 | 2020/05/14 10:17:20 | Error: A fatal exception has occurred. Program will exit.
ERROR | wrapper | 2020/05/14 10:17:20 | JVM exited while loading the application.
STATUS | wrapper | 2020/05/14 10:17:25 | Reloading Wrapper configuration…
STATUS | wrapper | 2020/05/14 10:17:25 | Launching a JVM…
INFO | jvm 4 | 2020/05/14 10:17:25 | [0.003s][warning][gc] -Xloggc is deprecated. Will use -Xlog:gc:C:/Program Files/Inductive Automation/Ignition/logs/javagc-20200514101725.log instead.
INFO | jvm 4 | 2020/05/14 10:17:25 | Unrecognized VM option ‘PrintGCTimeStamps’
INFO | jvm 4 | 2020/05/14 10:17:25 | Error: Could not create the Java Virtual Machine.
INFO | jvm 4 | 2020/05/14 10:17:25 | Error: A fatal exception has occurred. Program will exit.
ERROR | wrapper | 2020/05/14 10:17:25 | JVM exited while loading the application.
STATUS | wrapper | 2020/05/14 10:17:30 | Reloading Wrapper configuration…
STATUS | wrapper | 2020/05/14 10:17:30 | Launching a JVM…
INFO | jvm 5 | 2020/05/14 10:17:30 | [0.004s][warning][gc] -Xloggc is deprecated. Will use -Xlog:gc:C:/Program Files/Inductive Automation/Ignition/logs/javagc-20200514101730.log instead.
INFO | jvm 5 | 2020/05/14 10:17:30 | Unrecognized VM option ‘PrintGCTimeStamps’
INFO | jvm 5 | 2020/05/14 10:17:30 | Error: Could not create the Java Virtual Machine.
INFO | jvm 5 | 2020/05/14 10:17:30 | Error: A fatal exception has occurred. Program will exit.
ERROR | wrapper | 2020/05/14 10:17:30 | JVM exited while loading the application.
STATUS | wrapper | 2020/05/14 10:17:35 | Reloading Wrapper configuration…
STATUS | wrapper | 2020/05/14 10:17:35 | Launching a JVM…
INFO | jvm 6 | 2020/05/14 10:17:35 | [0.003s][warning][gc] -Xloggc is deprecated. Will use -Xlog:gc:C:/Program Files/Inductive Automation/Ignition/logs/javagc-20200514101735.log instead.
INFO | jvm 6 | 2020/05/14 10:17:35 | Unrecognized VM option ‘PrintGCTimeStamps’
INFO | jvm 6 | 2020/05/14 10:17:35 | Error: Could not create the Java Virtual Machine.
INFO | jvm 6 | 2020/05/14 10:17:35 | Error: A fatal exception has occurred. Program will exit.
ERROR | wrapper | 2020/05/14 10:17:35 | JVM exited while loading the application.
FATAL | wrapper | 2020/05/14 10:17:35 | There were 5 failed launches in a row, each lasting less than 300 seconds. Giving up.
FATAL | wrapper | 2020/05/14 10:17:35 | There may be a configuration problem: please check the logs.
STATUS | wrapper | 2020/05/14 10:17:35 | <-- Wrapper Stopped
Remove this option. Java8 accepted it. Java11 doesn't.
hi
I am beginner in Ignition and have exactly the same problem.
Could you please advise me what to do next eg.
Java 8 i believe is current version for windows 10 - how to source Java 11 ?
You mentioned to “Remove this option” - could you please advise how to do it?
Thanks in advance for any help
Ignition 8 includes Java, you don't need to source anything.
If you're seeing this error restoring a backup it means the backup contains an ignition.conf that has this option set. You should be able to unzip the backup file and edit the ignition.conf.
If you're seeing this error in some other scenario you might want to start a new thread instead.
hi Kevin
Many thanks for your answer. Can i unzipped the gateway backup do the mod and compress it once again uzing zip or 7zip or is there a way to modify it inside the archive ?
Yes, using zip, not 7z or any other weird format.
That depends on your zip software.
thanks Kevin. Your help allowed me to restore the backup successfully.
